Power Window Repair
bf1967
Burlington, Wisconsin
2005 Golf
BrianCT said:
I've seen the clips myself, the OEM plastic and the "upgraded" warranty clips. The upgraded clips are made of metal and not plastic. I think the dealership is incorrect on their assumption and ...make certain they use the upgraded clips if this is the case.:D
Look's metal to me!
Courtesy of WorldImpex
The dealership wrong? Say it isn't so ;) . From what I can gather they went to metal clips around 2003, but it still sounds like there are some issues.
I'll be on them like white on rice...
paramedick
TDIClub Enthusiast, Vendor
Versailles, Kentucky
2015 Audi Q5 TDI
Yup, even some of the metal clips broke. Happened on our 03 Golf.
They do indeed glue the window into the clips. If you have some ice on the window, the clips can pull away from the glass. I glued both sides last winter when this happened. No more problem.
bf1967
2005 Golf
Thanks Bruce. I believe that's exactly what happened to mine (the ice that is). So the purpose of the glue is to keep the clip attached to the window. I missed that point from the previous posts.
I think I have the window curse. The same thing happened on my Chevy truck, except that's due to the crappy design. The best part about that is the OEM window mechanism is over $200. Very common problem on those trucks. GM wonders why it's in trouble... :eek:
For all the complaining we do about VOA, at least they manned up and admitted they have a problem and are providing a fix...
BrianCT
USA
I think it was after couple thousand windows fell inside the doors of these cars leaving customers at the mercy of the weather and a class action suit that prodded the cow to the corral.
I may be mistaken ...but I think that's how it went.:D
bf1967
2005 Golf
Sometimes that's what it takes I guess. I wish GM would have been prodded in that direction. Thier replacement setup is really expensive, and it's the same junk as when they built it.
swajsofa
Houston
00 Jetta; 03 Golf
This sounds exactly like what happened to me today. 03 TDI Golf, iced passenger window, wouldn't open, eventually fell down.
I bought it used, though, without any warranty documentation. Will I be covered?
Also, I've been trying to figure out how to take off the door panel. After fiddling with it for awhile, the trim cover seems more likely to break off than pop off. Besides, mine doesn't look anything like what's depicted in the manual.
Thanks in advance for any answers.
paramedick
2015 Audi Q5 TDI
Link below shows you how to disassemble the door and replace the window clips, if needed. If not, just glue the clips to the bottom of the window. Let the glue set 24 hours before lowering the windows.
http://forums.tdiclub.com/showthread.php?t=43368&page=4
waldo22
Chapel Hill, NC
2000 Golf TDI, 1981 Caddy 1.6 IDI
Any tips on how to get to the window regulator bolts when the window is down in the door?
I can't move the window at all to get it up to where I can expose the regulator clip bolts, so one of the regulators must still be "working".
Right now, I have a garbage bag duct-taped over my window :(
bf1967
2005 Golf
When I called the VW customer service line, they told me it was warrantied 7 years past the "in service" date of the car. I took my '05 in and they glued both front windows for me with their very special "channel bond" (that's what it was called on the receipt). I normally wouldn't let them touch the car, but it was cold outside and I didn't have the time to fool with it. Until I got there I was able to tape the window up in 3 spots. I put some paper over the painted surface so it wouldn't mess up the paint. Got the recalled brake switch done since I hadn't gotten to that yet.
Bob
swajsofa
Houston
00 Jetta; 03 Golf
Thanks for pointing those out. Very helpful. Got the glass back into the clips, which look like the new metal ones. So I guess all I need is this special glue. Any idea where to get it, perhaps a glass store?
Also, my fiddling caused some scratching. And suggestions how to fix that?
Thanks again
swajsofa
Houston
00 Jetta; 03 Golf
By the way, on these recalls and whatnot, is there a Web site on which to find them?
bf1967
2005 Golf
It's actually not a recall. They've simply extended the warranty on the window clips due to the problems. You can call the customer service 800 # to get more detailed info. I think there is a letter floating around here somewhere as well.
Bob
waldo22
Chapel Hill, NC
I was told by both VW of America customer dontcare and my local dealership service dept. that the Passats aren't covered, and I'll have to pay to have this fixed.
Maybe I should be more gentle pressing the button next time :rolleyes:
Any suggestions?
I can't drive my car over 45MPH right now as I have a damned trashbag duct-taped over the window hole.
Of course, it's rained just about every day since this happened.
:mad:
bf1967
2005 Golf
Any suggestions?
:mad:
Can you tell if the clips are actually broke, or if it just pulled loose. I suspect if it just came loose then you could just glue it (with JB Weld?) yourself.
Maybe somebody who has fixed a Passat window can chime in. I can't imagine it's much different than the Golf/Jetta window though.
waldo22
Chapel Hill, NC
I can't really tell yet.
The window is stuck down in the door, and it doesn't want me to pull it up.
Of course, I can't remove the door panel without getting the window out of the clips, so I'm in a catch 22.
If anyone's been in this situation before, please do chime in...
aaronvl
Viroqua, WI
Volkswagen Golf
I just had my passenger window fall down into the door. I am hoping i just need to reglue the clips. I was able to get the window up by using a pair of fish hook pliers from my fishing tackle.
bf1967
2005 Golf
If the window fell into the door. It's likely that its out of the clips anyhow. You should be able to get the carrier panel out so that you can access the window in the door. You'll need to support the window in the door frame then (with some tape?) so that you can get it back into the clips. You can JBWeld it then so it doesn't come out again.
Bob
waldo22
Chapel Hill, NC
Just wanted to update this thread.
The problem turned out to be that the cable came slightly off-track on the white window regulator wheel, and the motor just chewed the cable up.
It was a real BEAR to get the door panel off.
The window was down in the door, still attached to the regulator clips, so I couldn't move it up at all to get access to the bolts to loosen the window.
I had to pry the panel out from the frame with one hand, praying I didn't break the glass, while loosening the 10mm bolts on the regulator clips with the other, all while my arm was being pinched to death between the door frame and the regulator panel. Not fun.
Anyway, I ordered a replacement regulator panel from 1stwvparts.com (Auburn VW in Washington State).
It came with all the parts attached to the panel, so all I had to do was add my regulator motor and speaker and I was off to the races.
I just had to drill out the rivets for my speaker first, and move it to the new regulator panel, which was a pain, but other than that, it went smoothly.
-Wes
mactdi66
Ohio
2001, Golf, silver
The drivers window of my 2001 TDI dropped into the door the other day and I just started to research what it might be and how do I go about fixing it. My preliminary guess would be that the problem has something to do with "clips" that are known to break.
While scanning through this thread I came across something about a recall...we never got any recall for the drivers window dropping due to "broken clips"...that I'm sure of.
I do have the door panel lose, but have not removed it yet. Before I went too far, something told me I better do some research to find out more about what might be wrong. If I do need some parts, the closest VW dealer is 50 miles away and I am going there next week.
Any information about parts needed to repair the problem or if it is a good idea to replace other parts while I have the door apart...where to order from...any suggestions will be appreciated.
I have not checked to see if there are any How To(s) related to this problem or if there are other materials I need to read in order to educate myself to complete this fix, so, if anyone has such information, I would appreciate reviewing the necessary info.
Thanks in advance...mac
