Old May 17th, 2018, 06:41   #1
bmwM5power
bmwM5power's Avatar
Default Is anybody using LM2009?
Is anybody here using LM2009? Please, share your thoughts
https://www.kermatdi.com/i-827-liqui...ent-300ml.html
bmwM5power is offline   Reply With Quote
Old May 17th, 2018, 13:01   #2
KLXD
Reminds me of ARCO Graphite.
I wonders how small the MoS2 particles are.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old May 17th, 2018, 19:59   #3
James & Son
TDI(s): 2006 Jetta
They are micro not nano. Only usefull if you have minor ongoing damage or contact. This will impregnate the solid particles. Other wise do not use on a flat tappet cam as it blocks the oil entrance to the cam oil film. I think their other product that has both Boron and MOS2 might be better for rings and pistons. Actually they are really not cost effective on a
properly maintained motor.
James & Son is offline   Reply With Quote
Old May 18th, 2018, 04:51   #4
bmwM5power
bmwM5power's Avatar
Is ALH flat tappet style? I was gonna give it a shot
Old May 21st, 2018, 13:08   #5
20IndigoBlue02
20IndigoBlue02's Avatar
Why not use a oil that has a high amount of Moly from the start? Such as Redline Motor oil.
2016 Tiguan SE 4Motion
20IndigoBlue02 is online now   Reply With Quote
Old May 21st, 2018, 19:29   #6
MichaelB
Fuel Economy: very good
Forget about the additive. Rotella T6, Mobil 1 Delvac, Mobil 1 TDT will all serve you well without adding anything else to it. Redline will just rob your wallet. Yes, your engine has a flat tappet cam.
MichaelB is offline   Reply With Quote
Page generated in 0.17253 seconds with 10 queries
[Output: 70.04 Kb. compressed to 60.76 Kb. by saving 9.28 Kb. (13.25%)]
