Old February 8th, 2012, 13:24   #46
SignHere
SignHere's Avatar
Originally Posted by lilspoon View Post
I have always heard from fellow friends/mechanics that rotella is not the greatest oil to use. I will probably run valvoline like I have in all my diesels.
Just my opinion. Worries me that the dealers have stopped using 5w40 though.
It's your car man. 5w 30 eats cams and pisses metal shavings through your engine. Who cares what VW says. They deny the facts!
SignHere is offline   Reply With Quote
Old February 8th, 2012, 14:17   #47
Jnitrofish
Jnitrofish's Avatar
Fuel Economy: Bad on short trips, good on long trips.
Don't confuse the different oils that Shell sells under the Rotella name. The conventional Rotella T 15w-40 has definitely fallen from being the awesome oil it once was. At the very least there are a lot better conventional HDEO 15w-40 oils out there, like Delvac 1300 Super.
Rotella T6, is absolutely one of the best synthetic HDEOils you can find, no question in my mind.
T = Crap.
T6 = Excellence.
[ 2005.5 :: 06/05 Jetta 5m Franko6 BEW Cam/Malone Tuned - Equipped for towing (Bosal/Airlift/Tekonsha) || 2005.5 :: 05/05 Jetta 5m Tuned (Wife's Car) || 2006 :: 02/06 Jetta DSG Malone Tuned (Dad's Car) ]
[ 4 TDI tally: 4 cam jobs, 5 timing belts, 4 alternator pulleys, 2 DMF, 1 G60/VR6, 1 Jetta ] [ Explained engine vibration
Jnitrofish is offline   Reply With Quote
Old February 8th, 2012, 15:40   #48
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
You CAN get a 5w40 505.01, which is also MB 229.51. It is currently available at dealers, you may have to demand it be used in your PD, which is perfectly acceptable.
The oil is Castrol Edge Turbo Diesel, VW/Audi Part number: G 052167M2
SAE 5w40, fully synthetic motor oil.
2015 Golf SE TDI with DSG, 61k.
2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline   Reply With Quote
Old February 8th, 2012, 17:52   #49
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
T = Crap.
T6 = Excellence.
Rotella T 15w40 still has a good truck (medium and big) following, it can't be a bad oil.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old February 8th, 2012, 17:59   #50
Ski in NC
Fuel Economy: 48-52 typical
We use Rotella T 15w-40 on most of the four-stroke marine engines here. Never a problem. I consider it a good oil.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old February 8th, 2012, 18:31   #51
d-man
d-man's Avatar
TDI(s): 05 jetta PD
Fuel Economy: 50MPG
The four banger TDI does not get very hot, so a 15w-40 might be on the heavy side if your not doing long hard driving and will hurt fuel economy in short trip driving.
'05 MK4 Jetta PD,Wheat Beige, Kerma Tune, CCV 3.0, ScangaugeII, Ventectomy, Cat delete, muffler delete, 2.5" straight pipe with resonator, LuK DMF clutch kit, Monroe VR6 suspension, hidden hitch for bike carrier, evolution belly plate,Traxon E 75w-90 gear oil, Lucas break-in additive, Duron E 10w-40 summer, 0w-40 winter. Bosio 800 nozzles, Stage 2 colt cam.
d-man is offline   Reply With Quote
Old February 8th, 2012, 20:41   #52
obsidian
TDI(s): 06 Jetta
there you go.
obsidian is offline   Reply With Quote
Old February 8th, 2012, 20:48   #53
Dieselducky
Dieselducky's Avatar
Originally Posted by tupdegrove View Post
Thanks for the confirmation. It's nice to be able to use the same oil in the PD and motorcycle. Cheap too at Wally World.
check and make sure you can use it on the bike....would really suck wiping out the drive train on the bike buy not using a suitable
oil for wet clutches
Dieselducky is offline   Reply With Quote
Old February 8th, 2012, 21:13   #54
Jnitrofish
Jnitrofish's Avatar
I admit I was a little bit hard on Rotella T, calling it crap and all, but on my personal list, Rotella T would be pretty low. My short list for 15w-40 would be: Delvac, Supertech (Walmart), Delo, Motorcraft, Rotella T, other house brands.
Old February 8th, 2012, 21:25   #55
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
T6 is JASO MA, the previous version (RTS) was not.
Old February 9th, 2012, 07:17   #56
James & Son
TDI(s): 2006 Jetta
Originally Posted by obsidian View Post
there you go.
Here is the problem with the new formulations( Mobil 1 TDT and T6) and the TBN count. I just finished reading a study on Magnesium vs calcium on actual field tests. The conclusion was Magnesium by itself, plus wear metals and TBN showed that wear metals especially bearing metals started at a higher TBN and that TAN should also be taken into account. Calcium did better by itself than Magnesium but not much better with iron wear. The conclusion was that 6 to 1 ratio of calcium and magnesium resulted in the best wear of all metals. Both TDT and T6 have a 50/50 ratio.
The white paper conclusion was much more complicated as it was designed for the commercial truck analysis side of the business. My conclusion based on the field testing was you change out oil sooner than what the TBN indicates when you have doses of magnesium at greater than a 6 to 1 ratio.
Tool Slick has refined this to looking at the Boron count versus what the Boron starts out at and when that count gets down as another indicator.
I would say do not go by the TBN in the above oil analysis. The wear metals and the boron say you should change sooner.
Now if you just put the above aside and just say i am going to change at 10,000 miles, I think that would probably the easiest solution.
James & Son is offline   Reply With Quote
Old February 9th, 2012, 08:18   #57
cevans
TDI Parts Ninja Vendor
cevans's Avatar
Originally Posted by Joe_Meehan View Post
505.01 and 5w40 are not VW specific specs.
??? 505.01 is a VW specific specification...
There are official 505.01 oils not sold by VW of America. Lots of them, but they can be hard to find at local retailers. That Valvoline 5w40 I've seen around.
IDParts.com - IDParts.com Vendor Thread - The IDParts Blog - IDParts YouTube Channel
My Diesel "Addiction": '17 Canyon 2.8L DMax, '11 R350 BT, '06 E320 CDI // Past: 15' Ram ED, '13 NMS, '10 JSW, '10 Jetta Sedan, '07 R320 CDI, '03 Wagon, '00 Golf 2-Dr, '00 NB (Yellow :-)
Stop Hunting for Torque Specs - Get A Free IDParts Torque Spec Poster Today!
cevans is offline   Reply With Quote
Old February 27th, 2012, 06:53   #58
FXDL
Fuel Economy: 4.4 per 100KM's
Rotella T 15W40 can't be all bad as a friend changes the oil in his 2003 Dodge diesel only once a year and he puts on 80,000 km's a year on the truck and the truck now has over 650,000 km's on it and still runs great so the 15W40 can't be all bad. Syn., are better but with the 2003 truck above it makes me wonder some what. I have one thing to ask is the Shell T 6 a true syn., a type 4, or is it just a group 3 syn.?
FXDL is offline   Reply With Quote
Old February 27th, 2012, 07:41   #59
Jnitrofish
Jnitrofish's Avatar
I'm not going to ever be able live down saying Rotella T was crap...
T6 is a group III with some group IV tossed in for good measure.
Old February 27th, 2012, 08:11   #60
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
T6 is Group III+. No PAO, and no typical Group III.
Mobil 1 VS. Rotella T6 Poolboy1191 Fuels & Lubricants 40 November 24th, 2011 12:49
Rotella T6 in a PD, safe? turbocharged798 Fuels & Lubricants 14 June 6th, 2010 06:10
Rotella T 5w40 now Rotella T6??? Joester Fuels & Lubricants 13 February 5th, 2010 17:20
Rotella T6 & Rotella T SB? kwalsh24 Fuels & Lubricants 8 January 28th, 2010 17:38
Rotella T6 werewolf TDI 101 6 January 20th, 2010 16:42
Page generated in 0.18775 seconds with 11 queries
[Output: 140.30 Kb. compressed to 118.56 Kb. by saving 21.74 Kb. (15.49%)]
