Old February 1st, 2012, 17:20   #31
Spokane Walt
Originally Posted by Joe_Meehan View Post
505.01 and 5w40 are not VW specific specs.
Yeah, ummm...
The "505.01" IS a VW/AUDI Specification - It is a Mfg Specification by the engineers in Europe that designed the engine. The 5W40 Part is an international standard (SAE International) Due to the details of 505.01 -
The Majority of the 505.01 Oils are 5w40 and almost all of the 505.01 Oils were 5w40 when the spec was first released. Currently, there are a number of 5W30 Oils that meet 505.01 - and some of them are available in the USA - Valvoline SynPower 5W30 MST, which is only sold in 50+ Gallon Drums, and is available at many Valvoline Quick Lube type places as well as at some VW Dealerships, is VW Approved to 505.01 - Jiffy Lube can get sometimes get Shell Helix Diesel Ultra VA, which is approved to 505.01 as well. AS far as VW Warranty is concerned, just need to use an oil that meets the specification for the Engine in the ca.
Also, since there was discussion above about Valavoline SynPower 5W40....
If you can find the Valvoline SynPower 5W40 - It is VW/AUDI Approved Oil for 505.01 Specification (Approved by VW/AUDI -- and not just a claim by Valvoline- It is on the list) - I don't shop Wally World often, but the few times I have shopped there the Valvoline 5W40 was not on the shelf... Most NAPA Stores carry it, or can get it in a day or two....
Would the Rotella T6 5W40pass formal approval testing if tested by VW/AUDI??? Who knows - it seems to be really good oil based on testing and usage by people here on this forum...
W-
Spokane Walt - Using BioDiesel when I can
'00 Jetta TDI - 5sp, 00' Jetta 2.0L AEG AT(gas), '00 Jetta TDI w/ Auto (SOLD '07), Some parts from an '03 TDI Wagon (hulk has been recycled)
Spash Gaurds and Mudflaps Save Windshields. People who use fog lights when it isn't foggy are just contributing needlessly to OPEC.
Spokane Walt is offline   Reply With Quote
Old February 1st, 2012, 17:42   #32
Spokane Walt
Originally Posted by romad View Post
Ah, but is it Valvoline or VW that says it meets it? If it is certified by VW, all well and good. But if it is just a marketing claim by Valvoline, then not.
I'll look into the Liqui Moly and Pentosin availability/pricing at my local NAPA, but I suspect I'll end up staying with T6.
YES, Valvoline 5W40 Synpower, the one available in the USA, is on the VW/Audi Approved List - it was approved in August 2007 (formal approval letter from VW, Wolfsburg, Germany, is posted here on this web site somewhere). Note: I don't think it made it on the Nov 2007 Listing, or the JAN 08 Listing, Published by VW/Audi. It was added to later listings.
Old February 1st, 2012, 18:37   #33
bengone1
bengone1's Avatar
Fuel Economy: 40ish MPG
My .02c on the motorcycle usage:
I use it in my Suzuki SV650 and Kawasaki 650R with great results. I tried it in a sport bike that redlines to 13,500. It didn't sound too happy after a 20 min track session in cool weather. Switched to 10w-40 Mobil synthetic motorcycle oil and it sounded a lot better during a hotter track day. I don't believe it is built for high RPMs.
Great oil for a lot of vehicles. My lawn mower and generator love the stuff. In fact, scientists at NASA are researching T6 in pill form to combat cancer causing radiation in astronauts. Promising results in lab rats.
Malone tuning services available- Contact Ben at HRTechnikVA@gmail.com
http://malonetuning.com
MK4, B5, B5.5 remote window control recoding available and VCDS MK5/6. SKC retrieval, Cluster matching, IMMO programming/delete.
bengone1 is offline   Reply With Quote
Old February 2nd, 2012, 06:59   #34
tupdegrove
Yes, I just started using it in a Kawasaki 650R too.
tupdegrove is offline   Reply With Quote
Old February 2nd, 2012, 07:56   #35
bengone1
bengone1's Avatar
FYi
The clutch spring are weak from the factory. If the clutch starts slipping. It isn't the oil.
Old February 2nd, 2012, 08:01   #36
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
Originally Posted by Spokane Walt View Post
. Valvoline Quick Lube type places .. - Jiffy Lube
W-
Would anyone with an ounce of sense even drive into any quick lube place of any brand?
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old February 3rd, 2012, 01:11   #37
Spokane Walt
I am sure that there are some Quick Lube Places out there that do a good job... But, I also think Big Foot exists... Both are still to be proven...
Old February 3rd, 2012, 05:54   #38
Joe_Meehan
Joe_Meehan's Avatar
As for the VW 505.01 specification, that might be a concern during the warranty period but not any more as the warranty period is way past.
Why would you say that? As I understand it the 505.01 specification is really a group of specifications that the engines to which they apply need to protect the engine.
The 10W40 or like number is a measure of the thickness of the oil at specific temperatures.
They are not one or the other, the oil you use needs to meet both specifications for your VW.
Joe Meehan
Old February 4th, 2012, 14:01   #39
Jnitrofish
Jnitrofish's Avatar
Fuel Economy: Bad on short trips, good on long trips.
My engine will run so much better now.
[ 2005.5 :: 06/05 Jetta 5m Franko6 BEW Cam/Malone Tuned - Equipped for towing (Bosal/Airlift/Tekonsha) || 2005.5 :: 05/05 Jetta 5m Tuned (Wife's Car) || 2006 :: 02/06 Jetta DSG Malone Tuned (Dad's Car) ]
[ 4 TDI tally: 4 cam jobs, 5 timing belts, 4 alternator pulleys, 2 DMF, 1 G60/VR6, 1 Jetta ] [ Explained engine vibration
Jnitrofish is offline   Reply With Quote
Old February 4th, 2012, 14:23   #40
romad
romad's Avatar
I think you might have slightly overfilled it.
The fleet:
romad is offline   Reply With Quote
Old February 5th, 2012, 03:54   #41
Ted Hurst
Ted Hurst's Avatar
TDI(s): 2015 GSW
Fuel Economy: 45
I may stray from my Schaeffer's S9000 (No offense to my friends in St. Louis) and try the Rotella T6 5W40. I picked up a 5 qt jug on special at Autozone on sale some time ago. I can't decide if I want to use it in Mom's Passat 1.8t or my Jetta PD.
'15 White GSW 6M TDI S, 20K (New old stock)
'12 Candy White JSW 6M, 80k mi, Stock - Let VW Buyback.
'09 Reflex Silver JSW DSG, 63,500 - Rust colored coolant - Traded for above 2012 JSW
'06 Black Jetta DSG Special Edition, 138k Mi, Frost Heater, RC1+,HEX-CAN USB - Traded
Ted Hurst is offline   Reply With Quote
Old February 5th, 2012, 10:20   #42
romad
romad's Avatar
Where are you getting 5 qt. jugs? All I see are 4 qt (1 U.S. gallon).
The fleet:
Old February 6th, 2012, 03:48   #43
Ted Hurst
Ted Hurst's Avatar
TDI(s): 2015 GSW
Fuel Economy: 45
I was wrong. It's a 1 gallon jug.
Old February 6th, 2012, 10:19   #44
abctdi
abctdi's Avatar
1st fill of T6 in my PD this weekend, we'll so how it goes.
I'm right at 100k miles now and have been using M1 TDT lately.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old February 8th, 2012, 11:51   #45
lilspoon
TDI(s): 2004 jetta
Fuel Economy: Check my Fuelly
I have always heard from fellow friends/mechanics that rotella is not the greatest oil to use. I will probably run valvoline like I have in all my diesels.
Just my opinion. Worries me that the dealers have stopped using 5w40 though.
SPiT Diesel
Piss Excellence
lilspoon is offline   Reply With Quote
Mobil 1 VS. Rotella T6 Poolboy1191 Fuels & Lubricants 40 November 24th, 2011 12:49
Rotella T6 in a PD, safe? turbocharged798 Fuels & Lubricants 14 June 6th, 2010 06:10
Rotella T 5w40 now Rotella T6??? Joester Fuels & Lubricants 13 February 5th, 2010 17:20
Rotella T6 & Rotella T SB? kwalsh24 Fuels & Lubricants 8 January 28th, 2010 17:38
Rotella T6 werewolf TDI 101 6 January 20th, 2010 16:42
Page generated in 0.19140 seconds with 11 queries
[Output: 136.47 Kb. compressed to 114.32 Kb. by saving 22.16 Kb. (16.24%)]
