Amsoil In this Thread only
Which AMSOIL?
  • Total voters
    339
milehighassassin
Fort Collins, CO
2005 Golf TDi PD, Reflex Silver
GoFaster said:
The issue with Amsoil (in general) is that Amsoil themselves say that it meets or exceeds whatever standard you are talking about (505.01 in this case), but they have not gone through with the actual approval process to INDEPENDENTLY CERTIFY that it meets that standard.
VW publishes a list of oils that VW has approved against the 505.01 standard. There is no Amsoil oil to be found on that list.
That is different from saying the stuff is no good. But what it means is that IF something lubrication-related goes wrong, VW is not going to support warranty coverage on the grounds that you did not use oil that was officially approved to the 505.01 standard. Which means, you are going to have a battle on your hands.
There's the info the way I see it. Now it's your choice.
But AMSOIL WILL either warranty the engine on its own, or do the battle for you with VW to get it warrantied
tdi06
Cleveland, Ohio
06' Jetta tdi 5 spd
C'mon guys, cut all the crap. He asked a specific question about Amsoil 3000 and not for your views on using 505.01 oil or having it changed at the dealer or the warranty. Lets stay focused here and not turn this into a million post thread filled with nothing but opinions. A simple no would suffice.
TwoSlick
Dixie
2002 Audi TT Roadster, 1990 Audi 100
Amsoil 5w-40, CJ-4
Spoke to Amsoil tech services about this product, due out on 1 October. Looks like pricing will be the same as their 5w-40/VW 505.01, European oil, or a bit less than Delvac 1. Product will be available in quarts, gallons and 2.5 Gallon jugs.
This would be a better choice for older (non-PD) TDI's than the European 5w-40, since it's about 15% thicker in terms of high temp, high shear viscosity and it has higher levels of AW additives (zinc/phosphorus).
This should be a CJ-4/SM rated formulation, it can also be used in all modern gas engines if you'd like to simplify your life...;)
TS
d2305
Pensacola FL
14 Ram EcoDiesel
What about running it in PDs? I'm using the european formula now, and the UOA have been less than optimal.
wjdell
Central Florida
06 Jetta TDI DSG PKG 1 17" VV Campy White/Beige
Those less than optimal UOA's on AFL - are they posted. What was the milage, 5k 10k.
AMSOIL has two different 5W40 ?.
TwoSlick
Dixie
The additive chemistry is a variation of what Amsoil is using in their VW 505.01 oil. I don't think there would be a problem running this new 5w-40 in the PD's, but it's not explicitly recommended for that application. I'd wait and see how it does in older TDI's and then decide. The fact that's it's significantly thicker than the 5w-40/AFL product should reduce valvetrain wear. Howeve this is still an 8 TBN formulation, so I wouldn't necessarily expect it to last longer in service.
Yes, Amsoil will have two different 5w-40 in about two weeks, but there is a lot of overlap with these two oils. The basestock blends and additive chemistry looks very similar to me. The CJ-4 stuff simply has a higher additive treat rate of the same chemistry as the VW 505.01 product. Of course the CJ-4 stuff does have to meet all the HD engine sequence tests, so from that respect it may be a superior formulation.
TS
AndyH
Registered Vendor , w/Business number
San Antonio, TX
'97 Passat Wagon 410K RIP
AMSOIL CJ-4 5W-40 (DEO) Datasheet
Here's the pre-release datasheet for the new 5W-40 that will hit the streets on 1 Oct.
wjdell
Central Florida
This would have been the best choice for my Lambardini - and I could use in my Kubota. Wish I had known, I would have waited to order this. Does look a tad thicker than AFL.
TornadoRed
West Des Moines (formerly St Paul)
2003 Jetta TDI wagon, silver; 2003 Jetta TDI wagon, indigo blue; 2003 Golf GL 5-spd, red (PARTED); 2003 Golf GLS 5-spd, indigo blue (SOLD); 2003 Jetta TDI wagon, Candy White (SOLD)
TooSlick, do you sense any 'resistance' toward the CJ-4 rated motor oils? Or, to put it another way, do you believe there will be any hoarding of CI-4 and CI-4 Plus oils?
AutoUnionTypeC
Upstate N.Y.
A couple of questions if you don't mind. Firstly please define what year range you consider older, does my 2000 ALH fall into this range? Do you also feel this is a better choice then the VW spec oils 506.01 and 507.00 that are 0w-30 and 5w-30? Lastly, can you tell me whether Amsoil makes its own base stock, if not from whom does it purchase?
Regards
bowlerman
medford, NJ
2001 jetta tdi black
synthetic 10w-30 amsoil?
anybody use this, i bought a case because my lifters started tapping and was going to put thicker sythetic in there? anybody use it or like it?
Drivbiwire
Zehntes Jahr der Veteran
Boise, Idaho
2013 Passat TDI, Newmar Ventana 8.3L ISC 3945, 2016 E250 BT, 2000 Jetta TDI
Wrong oil and the fact is the 10w30 flows WORSE than ANY 5w40!
DO NOT USE IT! Only use the Amsoil 5w40 AFL which is approved for the TDI motors.
DB
Fortuna Wolf
Wilmington, NC
2002 Jetta TDI Auto Sedan
That's a graph of it at start up, I assume?
You could get away with using it with a preluber, but a preluber would probably solve your problem anyway. A 0W lube would be better.
Drivbiwire
Boise, Idaho
Yes a 0WXX would surpass the 5w40, again all you have to do is look at the first number.
The problem is that unless an oil has a VW 506.01 certification NO 30 Weights oils can be used in ANY TDI OF ANY YEAR.
The 10w30 is wrong in both viscosity requirements, too thick for cold start-ups, too thin once the engine reaches operating temperature since it is not properly additized under the 506.01 specification.
DB
TwoSlick
Dixie
This chart compares a 5w-40 synthetic to 10w-30/15w-40 conventional oils, so it's somewhat misleading.
Due to the slope of their relative viscosity/temp curves, a synthetic 10w-30 will actually be THINNER on startup than a synthetic 5w-40 in moderately cold conditions. Keep in mind the first number, ie the CCS (cold crank simulator) viscosity, is tested at temps far below 0F. In the case of a 5w, it's tested @ -22F and in the case of a 10w, it's tested @ -13F. Once you start heating up a 5w-40 and a 10w-30, the 10w-30 will thin more quickly since it's going to be a 30wt at operating temp. At moderately cold temps > 0F, the 10w-30 will actually be thinner to start with.
Having said all this, the Amsoil 10w-30 is NOT suitable for PD engines, however it's fine for cold weather use in older TDI engines as a substitute to the Amsoil 10w-40 or 15w-40.
By the way, Hi Pete...hope all's well with you!
Tooslick
TwoSlick
Dixie
AutoUnion,
To answer your questions:
I think it would be better than the AFL in any non-PD engine - specifically in terms of valvetrain wear and oil consumption
A 0w-30/VW 506.01 rated oil would be preferred in very cold weather. I haven't seen enough data in the VW 507.00 stuff yet to determine how well it holds up in this application.
Amsoil has various suppliers for their PAO and Ester basestocks, including ExxonMobil and Hatco Corp. The purchase additives from Lubrizol, Infineum and a number of other suppliers such as Roh Max
Andy,
Data sheets looks about like I'd expect - thanks for posting!...The CCS temp at -30C and HT/HS viscosity would indicate they're using a thicker basestock blend than in the AFL/5w-40. (This is necessary to meet all the HD diesel applications.) Also looks like an excellent "high mileage" oil for worn gas engines....
TS
tditom
Jackson, MI
formerly: 2001 Golf GL, '97 Passat (RIP) '98 NB, '05 B5 sedan
The problem is that unless an oil has a VW 506.01 certification NO 30 Weights oils can be used in ANY TDI OF ANY YEAR...
Even an oil with VW505.00 rating (Castrol 0W30) in a pre-PD? If it has the 505.00, I believe it is sufficient.
DB please explain. TIA.
newbeetleman
NE
none
Tooslick
I agree with what you said here and I have used it in my car....although only for a short time. I now use the European formula 5w-40 though...
mparker326
Knoxville, TN
Golf 2002 Gray
Why do you continue to make this incorrect statement? Look at the lowly 505.00 0w30 UOA's at ~15K miles from this thread: http://forums.tdiclub.com/showthread.php?t=137355
IndigoBlueWagon said:
So here's the latest update: sample taken last Friday at 14,600 miles since last change, 134,600 total miles on the engine.
Aluminum: 9,600: 3 14,600:3
Chromium 9,600: 1 14,600:1
Iron 9,600: 27 14,600:34
Copper 9,600: 2 14,600: 2
Lead 9,600: 4 14,600: 7
Tin 9,600: 3 14,600: 0
Molybdenum 9,600: 1 14,600: 1
Nickel 9,600: 1 14,600: 0
Maganese 9,600: 0 14,600: 0
Silver 9,600: 0 14,600: 0
Titanium 9,600: 0 14,600: 0
Potassium 9,600: 0 14,600: 0
Boron 9,600: 63 14,600: 48
Silicon 9,600: 3 14,600: 3
Sodium 9,600: 6 14,600: 6
Calcium 9,600: 1837 14,600: 2145
Magnesium 9,600: 97 14,600: 70
Phosphorus 9,600: 1027 14,600: 869
Zinc 9,600: 1288 14,600: 1048
Barium 9,600: 0 14,600: 0
Viscosity @ 210F 68.7
Flashpoint 420
Fuel <0.5
Antifreeze 0
Water 0
Insoluables (soot) 0.4
wjdell
Central Florida
I have been using Amsoil HD diesel 30 for 20 years. I just got the new 10W30/30, and it is not the same as the old ST 30. I am dropping it now for the new 5W40 CJ-4 for my Kubota and Lombardini. I have one gallon 10W30 left and no more, maybe its my imagination but the its not the same as the old 30. Neither is a 505.01, if I had a older diesel that could use a CF oil I would try their new 5W40 to be released October 1. Its a tad thicker than AFL.
That comparison interesting but that is a syn 5W40 oil compared to two conventional oils :).
Kier
Trenton NJ
2006.5 Jetta Limited Diesel Edition, DSG, Reflex Silver/Anthracite
Looks great on paper, but will it be OK without the sacred VW505.00 approval. Some non-PD oils like Mobil-1 0W-40 list the VW approval. I guess most non-PDs on the road are past the warrenty period.
TwoSlick
Dixie
I believe the Amsoil 5w-40 can be ordered after Oct 1st....
The new CJ-4 additive chemistry is supposed to be superior to CI-4+, but I haven't seen actual test data that shows that. This oil would have marginally better pumping characteristics in cold weather, compared to the Amsoil 10w-40, but the 12 TBN, 10w-40 will probably last longer in service.
TS
TornadoRed
Amsoil HDD 5w30 is a CI-4 Plus-rated motor oil, which is supposedly almost halfway to being a 40-weight oil. It might be worth considering.
TwoSlick
Dixie
TR,
The Series 3000, 5w-30 is going to be a bit thicker than the Amsoil 10w-30 under high temp, high shear rate conditions, due to it's much higher Viscosity Index, ie 174 vs 141 for the 10w-30/30wt, ACD product. Pumpability in very cold weather is also going to be better with the Amsoil 5w-30. It would be my choice for a cold climate. The main drawback to this product is the price, however the S3000 is certainly capable of going >>10,000 miles between changes and fuel efficiency will be a bit better than running an xw-40 grade.
TS
AndyH
San Antonio, TX
Ted - you're welcome! The datasheet was a pre-release freebie from the Dallas regional meeting.
DEO isn't yet available for on-line ordering. It probably won't go 'live' on that system until the 1 Oct public release date. The ladies at the order line are taking back-orders for it, though. As of this morning it hadn't arrived at the Dallas warehouse. I guess it will arrive Monday morning, just in time for Carl and the crew to start shipping it.
TR - one of the issues discussed at the meeting in Dallas is demand for CJ-4. There's a HUGE pre-buy going on right now in the medium and large truck world. Truckers are ordering 2007 trucks with 2006 engines so they can let someone else debug the new systems...and pay the approximately $8000 for the particulate filter. CI-4+ will be the main HDEO spec until at least 2010 when PC-11/CK-4 is due. Lubrizol published these sales estimates for CJ-4: 10% or less in 2006, 25% max in 2007, and 50% max in 2008. http://www.lubrizol.com/CJ-4/default.asp
Indigo: I'm still torn. My favorite oil is still the 5W-30 HDD. I have about 75,000 B4 TDI miles on it. I'm just finishing my bypass filter install on my B4V and planned on HDD. I'll see how I feel after I get the VOA results on DEO. :)
Andy
AndyH
San Antonio, TX
Sigh...another 600 mile round-trip to the Dallas warehouse in the morning...gonna get some of this oil and a new filter...the bypass will have to wait another 10K or so miles...;)
As for my ride...she's not the prettiest TDI around, but she's got SOUL...and lots of room! (There are two 30-gallon drums rolled in first.)
Andy
AndyH
San Antonio, TX
We have more choices for 2003 and earlier TDIs, as we aren't tied specifically to 505.00 for warranty the way the PD owners are. We can select 505.00, ACEA, and (last) API CD/CF for minimum warranty service requirements. Most of the owner's manuals for the earlier cars don't even list a VW spec in the front oil section you have to jump to the back for the 'driving in Europe' section. The main requirements are still the 5W-40 viscosity recommendation and the synthetic requirement.
Andy
