Old October 21st, 2018, 07:55   #826
Terry270
Originally Posted by adrian537 View Post
i have the 2micron pureflow and containment kit installed on my car. i am curious to know if my CP4 pump goes bad and i would take my car to the VW dealer (since i have the extended warranty) how would VW deal with my car. i assume they would look at my car, see that is "modified" because of the 2micron system and not want to touch my car? maybe i shouldn't have installed the 2micron pureflow and containment kit since i have the extended warranty? my DPF went bad recently and when i took the car to get it fixed thru the extended warranty they saw the Cim-Tek 70025 filter the 2micron system uses and when they saw "Bio Tek" written on the filter they were trying to accuse me of using bio-fuel that led to my damaged DPF.
Wouldn't hold up in court and they know it. Extra filtering has zero negative affects on anything. But also I would remove the kit honestly as long as it's under warranty. Would be great to have a brand new entire fuel system installed right before the warranty is up lol
2003 2dr Golf TDI-R32 bumpers, sideskirts and wheels, VNT17
2010 Audi A3 TDI-CR170, Malone stg3, ARP headstuds, GLI Brakes, 2micron fuel and serpentine belt protection kits
Terry270 is offline   Reply With Quote
Old October 22nd, 2018, 09:58   #827
mz1
mz1's Avatar
The downside of having such a time bomb (OEM fuel pump) is that even if and when vw should cover this malfunction under warranty (which is not 100% the case - they have gotten away in many cases blaming it on bad fuel quality) you risk being stranded in the middle of your journey or long vacation and being out of your ride for days.
mz1 is offline   Reply With Quote
Old October 23rd, 2018, 09:55   #828
FXDL
Fuel Economy: 4.4 per 100KM's
So do we have a system for 2015 Jetta TDI yet and where can I get this from.
FXDL is offline   Reply With Quote
Old October 24th, 2018, 04:34   #829
Growler
Got Soot Vendor
Growler's Avatar
it seems he only made a few of them for the 2015.
I got ahold of one but haven't installed it yet.
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old November 27th, 2018, 14:01   #830
jgiffard808
Hi I just recently picked up a 11 jsw tdi and was wondering if I could pick up one of the fuel filter kits from 2micron or if there was any alternatives? Been trying to research but this is all new to me. Thanks for any help.
jgiffard808 is offline   Reply With Quote
Old January 7th, 2019, 09:06   #831
KeyTDI
Me too...
His website is gone.
Does he still make or have them?
If not, anyone got one sitting around, PM me!
KeyTDI is offline   Reply With Quote
Old January 7th, 2019, 09:28   #832
MichaelB
Fuel Economy: very good
Just curious. Has anyone who has installed Andrews filtration kits had a HPFP failure and the filters saved the engine from catastrophic damage?
MichaelB is online now   Reply With Quote
Old January 8th, 2019, 12:37   #833
Kriesel
Kriesel's Avatar
Yes. I had a pump fail with the kit on it, and it saved the engine.
Kriesel is offline   Reply With Quote
Old January 8th, 2019, 20:04   #834
KeyTDI
So is he still making and selling them????
Old January 9th, 2019, 06:45   #835
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
No, he is no longer making these kits. Best you can hope for is to locate a used one. Keep searching the parts for sale forum. Good luck.
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Old April 13th, 2019, 06:15   #836
RabbitGTI
RabbitGTI's Avatar
Fuel Economy: Don't know. I just feed it and drive.
Another expensive option is to swap the HPFP for a more robust version, correct? Is there a thread on doing that?
Rabbit GTI racecar RIP, 84 Rabbit GTI, 88 Golf GL, 97 Passat TDI, 07 Jetta 2.5, 02 Beetle 2.0, 08 Jetta 2.5 with Aisin Box.
RabbitGTI is offline   Reply With Quote
Diesel Power Tuning Modules for VW Common Rail at kermaTDI VailPowder Vendor & GroupBuy items for sale 32 March 18th, 2015 17:18
VW utilisera un common rail en 2008? Nico3d3 Quebec 4 June 26th, 2007 16:41
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 06:15
VW move to Common Rail TDIdragon TDI News/Tech 81 June 12th, 2006 05:55
VW TDI common rail flappie VW MKIV-A4 TDIs (VE and PD) 77 May 25th, 2002 22:08
Page generated in 0.17305 seconds with 12 queries
[Output: 106.22 Kb. compressed to 90.25 Kb. by saving 15.97 Kb. (15.03%)]
