Geobmx4life
Any mods?
fouillard are you completely stock on the original turbo?
I didn't see how many miles/kms you have on the car but my 02 hot rod Jetta has about 350k miles and smokes blue on startup. It has been heavily modded since the factory warranty expired at 100k miles. The valve guides are pretty soft in these engines, and well worn after 100k miles. Once the guides are out of spec for wear (side deflection of valve stem) the seals go. The TDI makes enough boost to keep engine oil from entering the cylinders during normal driving through shot valve seals, but will leak overnight. On startup the next morning it burns off the oil that has leaked into the cylinders and causes the blue smoke.
I will be pulling my head and replacing the valve guides, seals, and keepers at my next timing belt interval. I will also do a 3 angle valve job while I have the head on the bench.
is it pretty safe to assume its my heater core, and for the $50 should I get one ordered ASAP and just have it on hand just in case?
whats the difference between the $50 one and the $150 oem one on idparts?
is there an upgraded/revised heater core that I should look for?
There goes Xmas, 8 hours labour book time and maybe an a/c recharge if you don't have the split case.well the car definitely smelled like sweet antifreeze when I got in it this morning...
guess I should order a heater core and call my mechanic
Here is a decent read on the subject:just to confirm.... youre driving down the highway, and the engine starts to run away... red line uncontrollably. what do you do to stop it? whats the proper procedure? I just seen the key west thread where the guy panicked and held in the clutch, and they figure thats what ruined his motor (bend rods). I would probably do the same!! clutch in is ALWAYS the first thing you do.
