Perpalerp
Just bought a 98 jetta tdi low kms seemed like a good deal I drove it for about 200 kms when it started acting up. it was driving great but when I let off the throttle there was nothing. I'd gear down still nothing then gear back up and it would be there until I let off again. a couple times I had to pull over and I could gear back up. I got to work shut the car off went out at lunch and wouldn't go. I found that a rubber boost hose going to intake manifold was split I figured no problem just needed to jimmy it up to get home. put it back together and still no go. after a couple days after work in a dark parking lot chasing my tail with glow plugs and fuel it turned out my timing was 180 degrees out. how does this even happen buddy said timing belt was new it didn't look it to me but not rotten or that terrible of shape. It seemed pretty tight how in the world would this happen without wrecking half the valves?? Any input or ideas I got it home and it won't start again not sure where to go from here?
