Old August 19th, 2011, 11:01   #1171
oxford_guy
TDI(s): Golf '11
Well, a lot of people don't live in places where that's an issue. In Canada, the Passat comes with a block heater. For people living in places like North Dakota, the lack of a block heater is a problem.
Heated lenses is another layer of complexity, like so many other things including sunroofs, navigation, backup cameras, airbags, seat belts, CD changers, ad infinitum.
LED lighting is more efficient than incandescent, unless the waste heat from incandescent bulbs is needed for heating purposes. So, for those who don't live in cold climates, LED is more attractive -- just like not having to pay for a block heater.
oxford_guy is offline   Reply With Quote
Old August 19th, 2011, 11:08   #1172
Is this true? I saw this posted about the '11 Jetta in Canada, too. Thought it was another myth like the glow plugs that come on when you open the driver's door. Remember that?
Old August 19th, 2011, 11:30   #1173
kjclow
Or the fuel pump starting when you hit the unlock button?
Old August 19th, 2011, 12:17   #1174
oxford_guy
TDI(s): Golf '11
I read somewhere that a block heater is standard for the Canadian 2012 Passat. What people in North Dakota are supposed to do remains to be seen, because I haven't seen any evidence that VW is allowing buyers to add this as an option.
Edit: This is odd. A listing in Texas shows a block heater.
Originally Posted by myturbodiesel
The VW Passat TDI SE ($25,995) comes with:
-17" "Sonoma" alloy wheels
-6 speed manual transmission
-fog lamps
-8 way driver power seat with power lumbar function (front-back only, not up-down) and 6 way manual passenger seat
-leatherette (vinyl) interior
-leather steering wheel, shift knob, and parking brake handle
-full multifunction steering wheel and display
-rear multilink suspension
-electric power assist steering (saves energy)
-premium 8 RCD 510 touchscreen 6cd changer radio
-bluetooth
-dual zone auto climate control
-cold weather pack (heated front seats and windshield washer nozzles)
-soft touch dashboard (higher quality plastic)
-engine block heater (standard in Canada)
-auto headlights / wipers and auto dimming interior rear mirror
-diversity antenna (gives a stronger radio signal)
-3 years/ 36,000 miles free scheduled service
If those specs are correct, it looks like all the TDIs have a block heater. Hmm...
link
Here is a Canadian specs listing.
FSF: Fuel System Failure. "Since the CR fuel system failure is so expensive, ... " — eddif
Old August 19th, 2011, 14:46   #1175
I wonder where myturbodiesel.com got that list. If it's from a VW web site I'd call it suspect. Lots of misinformation there. Also, this may be early data that doesn't play out in production. I'm betting there won't be a factory-installed block heater. To my knowledge no VW diesel car has had one.
Old August 19th, 2011, 16:27   #1176
atc98002
atc98002's Avatar
Can't speak for the TDI models, but the 2006 Jetta 2.5 I just traded in would power the fuel pump when the driver's door was unlocked and opened. The sound was pretty obvious. Only ran for a second or so to pressurize the lines.
2018 Subaru Outback 3.6R Touring
2005 Ram 1500
2013 VW GTI: daughter
2010 Routan gone, replaced with 2018 Pacifica Hybrid: other daughter has 3 kids
atc98002 is offline   Reply With Quote
Old August 19th, 2011, 16:41   #1177
WVU TDI
WVU TDI's Avatar
I've been wrong before, but I'm fairly certain the CRs are block heater equipped in Canuck land.
1997 Passat TDI (sold)
2001 Golf TDI (sold)
2010 4dr Golf TDI, 6M (sold)
2013 Passat TDI SE, 6M -- turbo failed at 9500 miles.
WVU TDI is offline   Reply With Quote
Old August 19th, 2011, 18:33   #1178
Derrel H Green
Derrel H Green's Avatar
Fuel Economy: Check my Fuelly
Thumbs up Correct
Here's one in Manitoba.
See: http://forums.tdiclub.com/member.php?u=70344
Unless Jack had it added as an option?
D
2010 JSW. Reflex Silver/Titan Interior. A TDI with DSG.
Dynoed 132 HP, 230 ft/lb torque at the wheels.
Traded the VW for a Mercedes Benz W-211 E-320 CDI 12-17-2011.
Dynoed 12-01-12 211 HP, 386 ft/lb torque at the wheels.
View my MBZ E-320 CDI Fuelly: http://www.fuelly.com/driver/derrelhgreen/E320
Compare our previous VW TDI JSW DSG Fuelly : http://www.fuelly.com/driver/derrelhgreen/Jetta
Derrel H Green is offline   Reply With Quote
Old August 19th, 2011, 19:34   #1179
PlaneCrazy
TDI(s): Gone...
I can definitely confirm that my Golf TDI came with a factory block heater, and an extension cord that plugs into a receptacle in the lower grille.
You can see the cord in my trunk just to the lower left in this picture, I keep it in the little storage cubbyhole there:
Mike
Hers: '17 Golf TSI Sportwagen 5-MT
His: '18 Sportwagen 6-MT 4MOTION
'16 Marinoni Genius/Campy Record, '94 Marinoni Special/Campy Record
PlaneCrazy is offline   Reply With Quote
Old August 19th, 2011, 19:37   #1180
Is it a block heater or a coolant heater? Where does it live? Curious because since the days of my '78 Rabbit VW has been reluctant to say they would provide or approve of block heaters. If they now have them that's great. But it seems to be a significant change in direction. I'm also wondering why they think the common rail cars need them.
Old August 19th, 2011, 19:38   #1181
WVU TDI
WVU TDI's Avatar
Oh. It may be a coolant heater, probably is in fact, I just went generic with block heater.
Old August 20th, 2011, 05:30   #1182
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
It's a coolant heater, along the lines of a Frostheater, although ETKA uses the terms interchangeably.
The hose between the thermostat-oil cooler-heater core pipe and the oil cooler is replaced by the heater hardware.
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is offline   Reply With Quote
Old August 20th, 2011, 07:34   #1183
PlaneCrazy
TDI(s): Gone...
I haven't a clue what it heats, but the VW.ca website says this on its Golf TDI specifications page:
2.0 TDI, 140 horsepower engine with 6-speed manual
2.0 TDI, 140 horsepower, 6-speed DSG automatic engine with Tiptronic®
16” alloy wheels
Heatable front seats and washer nozzles
Electronic Stability Control (ESC)
Fog Lights
Engine block heater
Golf TDI Features & Specs
I had a look under the hood but with all the shrouds, wiring harnesses and equipment I can't see where the power line goes to.
On the grille though, this is where it plugs in, under a little spring loaded cover near the left foglight.
Cover closed:
Cover opened:
Mike
Old August 20th, 2011, 08:59   #1184
GraniteRooster
GraniteRooster's Avatar
TDI(s): '12 JSW 6MT
Fuel Economy: 41 Winter | 45 Summer
That is cool - I want that!! The fogs would be nice too while I am at it. Can we order the heater, harness & plug here in US??
I did not have issues last winter which was cold, but insurance never hurts....
2012 JSW | 6MT | Candy White | Cornsilk | Pano Roof | Huper Optik ESC 45 | Sport Protection Kit | Panzer Plate | VCDS
^^~^^ Mambo | X-Ice Xi2 ^^~^^ Goal | Pilot Super Sport
FOR SALE: '12 Jetta Sportwagen 6MT
GraniteRooster is offline   Reply With Quote
Old August 20th, 2011, 11:37   #1185
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
As far as the VW parts distribution network is concerned, the US and Canada are the same region, so yes.
New Polo confirmed for the USA, with TDI characterzero TDI News/Tech 516 May 21st, 2012 19:40
Rabbit GT TDI confirmed at Dealer Meeting twigless General VW Discussion 45 February 25th, 2011 06:16
2010 TDI golf confirmed for North America winterlocked VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 956 May 29th, 2010 20:16
Possible fuel pump "confirmed kill" with a 96 tdi ybiofuels Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 5 August 17th, 2004 10:04
Confirmed: Not all MkIV's have immobilizers! TDIBri VW MKIV-A4 TDIs (VE and PD) 22 April 8th, 2004 13:10
Page generated in 0.21336 seconds with 13 queries
[Output: 141.71 Kb. compressed to 119.57 Kb. by saving 22.14 Kb. (15.63%)]
