Nissan2000
My Beetle all of a sudden crank but don't start . I bought the Haynes repair book and I'm checking every component. I started with the fuel injection pump and according to the book the resistance is off in the pins 1and 3 . It suppose to have between 4 and 7 and it has 11 ohms so does it mean that the pump is bad? . The other two measurement are correct so I really don't know. I have been reading the post and no body have had problems with the pump. I just order the relay 109 and the fuel filter. Also no codes. Glow light comes on for two seconds . I open the fuel lines and fuel spill a little bit but not as much as I thought. I disconnect the fuel return line from the filter and there is no fuel coming out. So please some tell me what to do next or what to check?
