travis45
I'm wondering if I can get some opinions this weekend on my CR engine rebuild. I'd like to know what you think about where I'm at with piston to head clearance and what the implications will be. Engine is at a local reputable engine shop that does a lot of diesel work.
Quick summary of the build:
-IE Tuscan Rods
-Fresh bearings and rings all around
-Main and head studs
-Machined pistons for slightly lower compression ratio
-Port and polished head
-Valve job
-Upgraded valve springs
-Colt stage 2 cams
-GTB2260vklr turbo
-Darkside intercooler/piping
-CP3 Pump w/Bobby Singh injectors
So the engine shop reassembled the short block and we had 1.27mm piston protrusion. With a 3 hole head gasket (1.71mm thick) that left me with .44mm piston to head clearance. Tight according to the engine shop. We spoke on the phone and agreed to machine the pistons and skim a bit off to allow for more clearance.
In the meantime, with some help from top members in this group (TDISyncro, MacRadiators - thanks guys), I've come to learn that the spec I'm looking for is .5mm-.6mm clearance.
Then I found out the shop took off .635mm. This leaves me with a new piston protrusion of .635mm. With a one hole gasket (1.55mm thick) I'd have .915mm clearance. Puts me .315mm fat on the clearance.
I'm trying to decide if I should have the shop deck the block back down to get me within that .5mm-.6mm spec. At this time the car will see a half dozen or so track days a year and is not really a daily driver. Maybe compound turbos someday.... What will that extra head space do? Probably more smoke? Lower compression ratio too much? Was shooting for about 15.5:1.
Roll with it or have them disassemble the block and deck it down to get in spec?
All opinions appreciated.
-IE Tuscan Rods
-Valve job
-Colt stage 2 cams
-GTB2260vklr turbo
