Svën Höek
HI guys, I'm a long long time vortex user and even longer vw owner.
I've got a tdi i picked up last year, put some work into, commuted with it for a bit and then moved on to another vehicle. I'd like to get rid of it while it's still summer so if any new owner sees fit, they might have time to add their own personal touches or fix a few easy things.
1996 TDI sedan, about 305k. $2300 OBO. seriously, best offer, I need to get rid of this car, OPEN TO TRADES. if trades are parts related, all i can use at this point are 5 lug or adaptable to 5x100 mk3
06606 connecticut.
brand new battery. 11/15
all recent work done 10/15 - 11/15
new front brake rotors and pads.
new control arm bushings ball joints, passenger tie rod, driver tie rod end.
new oil return line.
pressure pipe coupler, intake manifold coupler, oil cap gasket, valve cover gasket.
engine and bay recently degreased and cleaned.
has raceland coilovers.
mk3 front seats, mismatched mk3/b4 rear seats.
has yellowed fogs and hi beams. all lighting works.
no CEL
gas gauge doesn't always work. getting about 36-38mpg winter gas lately...
recently stripped the entire interior and cleaned everything. headliner is replaced.
rear power windows don't work, I have 2 complete doors to go with the sale.
misc B4 parts available at request. extra set of headlights, misc switches and dash bezel....
comes on 4x100 steelies. I have 2 good snow tires also on steelies.
needs rear brakes done. bearings are fine so it's not an imperative immediate issue just has old/worn rotors and pads. passenger side rear caliper parking brake lever seems locked, may need replacement, parking cables need to be replaced.
has block heater
hood bra
mk3 dual tip 2.25 magnaflow custom fit exhaust
rear doors have bondo on the lower edges.. car comes with 2 rear doors if you want to replace...
new waterpump 1/16
2 snow tires on steelies will be in the trunk.
one of this car's previous owners rolled the front fenders poorly.
paint is not great, clear is peeling, decklid is a different color white.
theres no radio.
I have lots of B4 misc parts. I'll basically fill the trunk with random parts you can sort out/use/discard at your leisure. I've had a few passats but once this one is gone, I don't need any of the random B4 specific stuff anymore.
email me for a quicker reply.
VOLKSWOOKIEE@gmail.com
06606 connecticut.
no CEL
has block heater
hood bra
new waterpump 1/16
theres no radio.
