Hello Everyone,
A while back i installed a boost control device (Dawes) worked great, boost would spike at 20 and then settle at 17psi.
But now its spiking at 27psi, while accelerating from a stand still (never occurred before).
I have taken apart the boost control valve cleaned it and still the problem occurs. ( the valve is set on its minimal setting, its only holding with a few threads)
A few days before this there was a buzzing sound when the engine was switched off, a few people said that it might be the N75 valve. Would a failing/bad N75 valve cause this sudden rise in boost spiking??
Thanks for the help again
Sher
01 Jetta auto
192000km
Chip+.184’s
Sher
01 Jetta auto
192000km
Chip+.184’s
