Resetting "check engine" light?
willwin2day
Resetting \"check engine\" light?
I think I already know the answer to this, but is there a way to reset the "check engine" light without the use of a vagcom? Thanks!
MOGolf
underneath something
2001 Golf GLS TDI Reflex silver, rough road suspension and steel skid plate, 2004 Passat Variant, Candy White, rough road suspension and geared balanced shaft module, and much, much more. 2016 LR RR HSE TD6, 2019 Jaguar I-PACE
Depending on the fault, it may turn itself off after 4-50 start and drive cycles.
NadaGasser
Green Valley, AZ
1999.5 Jetta TDI
My '97 B4's CEL goes off after starting the engine and 30 or so seconds later, it comes on and stays on until the engine is shut off. It will do this religiously EVERY time. I suspect there is some corrosion on one or more of the glow plug connector tips.
