Changing to a new turbo and found the old turbine in the exhaust hung on o2 sensor. In the process of removing it slid past o2 back towards the cat and now I don't know what to do. Help help help need to drive tomorrow!
Turn the car on end and shake?
Seriously, call Uber.
Don't believe that's ferrous, so a magnet won't work. So there's long needle nose, bent wire, any way to get a hold of it. I will interweb guess it's in there good and you'll need to remove some pipe or maybe just the sensor. Neither will be easy on a car that old.
I had to try it and no, a magnet does not stick to the turbine of the 1756 on my
workbench. I think I would start removing the exhaust hangers to lower it and shake.
Unbolt the slip clamp after the cat and pull the down pipe out of the car - you already have the front detached from the turbo. Worst case - remove the O2 sensor and dump the wheel back out.
