GTADoum
Hello,
On my '00 Jetta TDI, the AC does not work properly, the low pressure is too high (over 70 psi) and the high pressure is too low (90~100 psi). Because of the high pressure on low side, it is difficult to charge the system, sometimes the low pressure gets lower and I used that to manage to get some gaz into it.
I played with it for few days and checked the pressures every evening. The fans are working properly, as the compressor clutch. Sometimes the clutch does not disengage when I turn the AC off, but it does disengage if I turn the motor off then restart it.
On each evening, the pressure is about the same before I start playing with it, so it does not seem to leak.
Tonight I noticed that if I shut the AC off, then on after few seconds, low pressure gets low for a short period of time (~50 psi) then slowly climbs up to 70~80. High side is steady at ~95psi. I tried to add more gaz into it, since I guess the previous one did not completely discharge into the system and it probably is undercharged. I'm using RedTek 12a, so my leakage to atmosphere is human friendly .
Any idea what is going on? Any suggestions as to what to check to confirm what is defective?
