Hiyo,
I just did a 50 mile highway trip at about a constant speed of 70 and I noticed my rear windshield started getting more and more murky on my way home. Turns out it was oil and its all over the back of my car. No oil was leaking from my exaust but I pulled off the plastic skid plate and covered the ground with oil.
There's a bit of a hiss when driving and a little part of the intake manifold was a little damp but I figured that I'd go and replace the gasket later and make sure all the bolts were tight. Most of the oil seems to be coming from the back of the engine, but I can't really tell with the amount of oil everywhere. I did my best to clean it up and wipe everything down but I've only got a few ruined t-shirts now and no better idea of where the oil leak is.
My coolent is the exact same level, but there's a lot of excess white smoke from the oil cap when I take it off. Could just be because the engine is still pretty hot.
Is there any common points where oil leaks spring up. I have a BEW engine.
Sent from my VS988 using Tapatalk
