Old February 24th, 2013, 15:49   #1
TDI4evah
TDI(s): 2002 Jetta
Default 02M conversions and heat shields?
Hi All;
I finally got the 02M installed with a rebuilt engine in my 2003 wagon. Putting things back together today, I found that the heat shield around the inner CV joint rubs a little on the CV joint itself. It doesn't appear to be rubbing on the rubber bellows, but I'd like it not to rub at all.
Is this common? Is there an 02M heat shield that's just a little bigger than stock?
Thanks!
TDI4evah is offline   Reply With Quote
Old February 24th, 2013, 20:14   #2
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Have a look at the little rings in the bolt holes of the shield. If they are loose in the holes then the shield will not sit right. I see this a lot and I usually let it slide on 02J joints but I had to buy a new shield for my GF's wagon swap when I put a 6 in it. Dang thing is like $75.
runonbeer is offline   Reply With Quote
Old February 25th, 2013, 16:08   #3
boertje
boertje's Avatar
You can cock that heat shield around a little on the mounting bolts. Lower the heat shield on the passenger side bolt of the heat shield and raise the heat shield on the driver side bolt of the heat shield as much as possible and that should tilt it enought to clear it. On my Jetta, I have had to heat the shield with a torch just enough to bend it to clear the CV. Anyway for $75 bux, I'd try a little heat first. It worked for me.
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline   Reply With Quote
RYAN P's 6 speed 02M Conversions and ALL Euro TDI Parts ryanp Vendor & GroupBuy items for sale 450 July 10th, 2018 08:37
RyanP's 02M 6 Speed Tranny Conversions for VW Golf Mk4 (A4) ryanp Vendor & GroupBuy items for sale 289 January 7th, 2013 03:07
Ryan P's 02M 6 Speed Tranny Conversions - 1100 inc SHIPPING!! ryanp Vendor & GroupBuy items for sale 326 December 19th, 2011 01:30
6 Speed 02M gearbox conversions ryanp Vendor & GroupBuy items for sale 91 May 26th, 2011 21:12
Necessary heat shields jmcfarland56 TDI 101 1 July 31st, 2009 12:32
Page generated in 0.13503 seconds with 11 queries
[Output: 58.46 Kb. compressed to 53.10 Kb. by saving 5.36 Kb. (9.16%)]
