Closed Thread
Old October 6th, 2011, 07:07   #1
ryanp
ryanp's Avatar
Default RyanP's 02M 6 Speed Tranny Conversions for VW Golf Mk4 (A4)
LAST UPDATED January 2013 - CONVERSIONS ARE STILL AVAILABLE!!!
PLEASE SUBSCRIBE TO MY NEW CONSOLIDATED THREAD HERE:
http://forums.tdiclub.com/showthread...19#post4052519
Thanks!
Hi,
I decided to do a new 6 Speed Conversion Topic as I know the old one was getting dated. You can find that here
We have sold over 200 of these 6 Speed conversions now, so there are a lot of very happy people cruising on the freeway in 6th!
The standard 5 to 6 Speed setup comes with all the items you see in the picture. It is everything you need to upgrade from a 5 Speed Manual to the 6 Speed. A few more parts are needed to swap out an Auto (see below for prices).
5 Speed Manual to 6 Speed Parts list:
02M 6 Speed Gearbox
2 x Drive Shafts
Used Dual Mass Flywheel and Clutch Kit
Gearbox Mount
Dog Bone Mount
Starter Motor
Dust Tins from the Engine
Shifter Mount and End Links
All bolts required (New where needed)
Linkage Cables (if required)
Please remember that if you are converting from a 5 Speed, you will have everything available to sell your old setup as a complete conversion for the Auto guys.
I can also supply the kits with a Brand New PD150 OEM Sachs Dual Mass Flywheel and Clutch kit with Release Bearing, when shipped with a 6 Speed they are 300 GBP extra. These are good for 200hp and 330lbs/ft.
We can also get any of the SouthBend Kits shipped directly to the USA and Canada at good prices.
Here are the different 02M Subcode ratios that are available to compare:
To compare RPM and Speeds against all the VW TDI Gearboxes, see the following calculator:
VW TDI Gearbox Ratio Calculator - Thanks Dave (Deebeaux)
AUTO TO MANUAL CUSTOMERS
I can supply all the extra parts you require, including the Clutch Pedal Assembly, for 300 GBP extra.
FOR THE AUTO TO 6 SPEED SWAP, PLEASE TAKE A LOOK AT THIS FATASTIC GUIDE BY BOERTJE - Auto to 6 Speed 02M Swap with Wiring Instructions
So to summarise:
5 to 6 Speed Swap - 1200 GBP
New Sachs PD150 Dual Mass Flywheel, Clutch Kit and Releaser - 300 extra
Complete Auto - Manual Setup - 300 GBP Extra
Peloquin Installation including Upgraded forks - 900 GBP extra
6 Speed Clutch Fluid Line - 60 Extra (Included in Auto-Manual Parts)
All prices quoted are in / GBP / British Pound and INCLUDE DHL EXPRESS SHIPPING to the USA and Canada. For estimated conversion rates, please check http://www.xe.com/.
I can take payment by Bank Transfer, Credit Card through my website (2% charge to cover fees) or PayPal (4% charge to cover fees).
For a limited time, with any 6 Speed Conversion we are offering a FREE PD150 TIP Kit or PD150 Intake.
Thanks for looking!
Ryan
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline
Old October 6th, 2011, 09:00   #2
boertje
boertje's Avatar
This kit will work with the bug too although the ECU is located under the dash panel just in front of the instrument cluster. Its really fun to get to. Other than that, its the same process.
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline
Old October 6th, 2011, 10:40   #3
JBE
You can count me as one of those 120 satisfied customers. The auto to 6 speed swap was a piece of cake, and Ryan was great to deal with. Worth every penny. Thanks Ryan!
JBE is offline
Old October 6th, 2011, 11:49   #4
Nash_TDI
Veteran Member -TDIClub Enthusiast
Nash_TDI's Avatar
Fuel Economy: 63.25mpg max
I can't stop grinning after the 5spd to 6spd swap. Can't imagine the joy of auto to 6spd.
2.0 ALH, GTB2260, 12mm, etc, etc.....
www.nashimporters.com http://louisvillevw.org/
TDI Repair Available, TBs, Clutches, Manual Swaps, BSM, etc..
PD Cam tools, BSM tool, VE & PD TB tool rental available.
Nash_TDI is offline
Old October 8th, 2011, 12:17   #5
ryanp
ryanp's Avatar
Just as a reminder for any of the Mk5 Golf guys, I also do 6 Speed Swaps for you!
http://forums.tdiclub.com/showthread.php?t=330432
Cheers
Ry
ryanp is offline
Old October 9th, 2011, 21:29   #6
Der MEKnIZEd Wolf
Dubbler
Der MEKnIZEd Wolf's Avatar
TDI(s): '00 GOLF
Fuel Economy: Stopped Keepin' Track
I haven't finished the task of my swap "526", and can't wait till she's compressin' some sixth.
Ryan is straight up and a excellent communicator. Best deal, since I bought my car.
Many thanks Ry,
Cheers
SDMF....and don't be bellignorant!!!.....})~
Der MEKnIZEd Wolf is offline
Old October 12th, 2011, 01:49   #7
Kree
Kree's Avatar
TDI(s): 99.5 Golf
Fuel Economy: AVG 48 BEST 56
What is the average rpm in 6th at 80mph?
99.5 ALH/02J Golf 2dr- 17/22 Turbo, FMIC, PP764 Injectors, 11mm IP, HammerMod, KERMaTune, DieselGeek EGR delete, KERMA 3" turbo back exhaust, SB Stage V Clutch, VR6 AXLES, MK5 front bumper update, Black Ecode headlights, Euro CAN Cluster
Kree is offline
Old October 12th, 2011, 03:29   #8
ryanp
ryanp's Avatar
Hi,
Just added this to the first post:
http://supradave.com/tech/gearspeed/comparator.php
Thanks Dave (Deebeaux)!!!
Hope that helps!
Ry
ryanp is offline
Old October 12th, 2011, 12:41   #9
08jetvette
Do you have a DRW available?
08jetvette is offline
Old October 12th, 2011, 13:02   #10
ryanp
ryanp's Avatar
Yeah, i have a few in stock, drop me a pm if you need to discuss the finer details!
Thanks!
ryanp is offline
Old October 14th, 2011, 10:19   #11
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
How much for just the ERF trans and nothing else?
turbocharged798 is offline
Old October 14th, 2011, 10:42   #12
ryanp
ryanp's Avatar
PM'd
ryanp is offline
Old October 17th, 2011, 15:52   #13
temporaptor
temporaptor's Avatar
Fuel Economy: 44 MPG
but my GPS at 80 MPH, I'm at about 2,400 - 2,500 RPM
this is a EFF 02M. Loving it every time I drive.
00 Jetta TDTuning stage 3+, GTB1756vk - sold
04 V10 TDI Touareg - sold
11 335d - sold
SSBMWO 2012 X5 xdrive35d
2014 Chevy SS LS3 415hp 415 tq
temporaptor is offline
Old October 19th, 2011, 02:06   #14
ryanp
ryanp's Avatar
Still got stock of these!
ryanp is offline
Old October 19th, 2011, 05:16   #15
NewOwner
TDI(s): 2002 Jetta
I am also one of the happy customer. Ryan is great to deal with. Other side of him is "kind and humble" - Thank you Ryan.
NewOwner is offline
Closed Thread
A5 Golf / Jetta Mk5 02Q 6 Speed Tranny Conversions ryanp Vendor & GroupBuy items for sale 8 January 7th, 2013 04:02
Ryan P's 02M 6 Speed Tranny Conversions - 1100 inc SHIPPING!! ryanp Vendor & GroupBuy items for sale 326 December 19th, 2011 02:30
6 Speed 02M gearbox conversions ryanp Vendor & GroupBuy items for sale 91 May 26th, 2011 22:12
5 speed Mk4 tranny on ebay ( Maine ) Threewheelin007 TDI 101 1 November 12th, 2010 10:59
Conv 2002 VW 337 6 Speed GTI Tranny into a 2003 Golf TDI RallyXI TDI Power Enhancements 5 November 3rd, 2007 08:32
Page generated in 0.20749 seconds with 11 queries
[Output: 132.72 Kb. compressed to 111.31 Kb. by saving 21.41 Kb. (16.13%)]
