Closed Thread
Old October 21st, 2010, 09:22   #1
ryanp
ryanp's Avatar
Default Ryan P's Euro TDI Parts - Intakes, TIP's, R32 DSG Snorkles, Turbo's, Injectors etc
I am based in the UK and have contacts throughout Europe so I can get hold of the best Euro parts at the best prices!
Here is a small selection of what I can get.
All prices quoted are in / GBP / British Pound and INCLUDE DHL EXPRESS SHIPPING to the USA and Canada. For estimated conversion rates, please check http://www.xe.com/.
Intakes
All of these intakes will bolt up to all PD and VE heads with the same gasket as the stock intake. They will also fit the AAZ TD if you are an IDI guy!
PD150 Intakes
PD150 Intake manifold (Bare) - 140 Much better than the stock ALH intake and wont kill your engine like the US PD intakes do when they ingest the butterflies.
Complete PD150 Intake with EGR and Elbow Pipe - 175
Can also be supplied with EGR Cooler for 10 Extra
Passat RHS / Driver side PD Intake
Passat RHS PD intakes (Bare) - 140 These are required if you want a clean install for a FMIC to cut down on excessive pipework.
SDI ‘Snail’ Intake
These are the best inlet I’ve come across so far, the runners are over a foot long and it has a large plenum and fits in a very compact space.
With Genuine VW 'RacePipe' (2.5"), Genuine VW EGR Blank and Plugged Breather Hole. READY TO FIT - 175
PD150 TIP Kit’s
They come complete with everything you need to fit them - 140
For an extra 70 when purchased with a TIP Kit I can supply a R32 DSG Snorkel Kit (a small mod to the Air box bottom is needed for the MUCH larger snorkel)
If you want a complete OEM setup the R32 air box kit (including new filter element, the Air box Bottom is NOT available on itself) can be purchased for an extra 100 on top of the snorkle price - The R32 Airbox and Snorkle are 170 combined
This will need to be used with a R32 MAF housing, the PD150 accordion hose will slip over the MAF with a little persuasion to make the largest OEM Intake setup. I can supply a new R32 DSG MAF sensor for 125
If you already purchased a TIP kit shipping will be 50 for the above 2 items together due to the size of the box!
PD150 GT1749VB Turbo Also known as the VNT-17
New - 700 Shipped
Used - 475 Shipped
VNT-17s are shipped with either the Red Outlet Pipe or Modified to fit the ALH / BEW Directly (welded outlet)
cont...
ryanp is offline
Old October 21st, 2010, 09:26   #2
ryanp
ryanp's Avatar
TDI Braided Oil Feed
These are a direct fit on just about any Turbocharger on the 1.9 TDI Engines (VE and PD). These are reusable and easy to remove still fitted to the turbocharger.
50 inc Shipping with Royal Mail
PD150 Injectors
335 inc Shipping for the Injectors and 415 inc Shipping with New Bosch Seals and Bolt Kit
These are a perfect upgrade to take the PD100 BEW and BRM to the next stage!
3 BAR MAPS
Brand NEW, GENUINE VW 3 BAR Map Sensors. Ideal upgrade from the standard 2.5 BAR MAP sensor, as the standard 2.5 BAR will not read any more than 1.5 BAR (Relative). Obviously your car would be mapped to take into account the new sensor.
VW Part Number - - - 038 906 051 C (038906051 C) (038906051C)
Bosch Part Number - - - 0 281 002 401 (0281 002 401) (0281002401)
20 if shipped with another purchase, 30 Shipped by itself, to the USA and Canada (Will Post Worldwide)
These are the small probe MAP sensors, so would require a rubber spacer if fitting in the place of the early, large probe sensor. These are 2 extra.
4 BAR MAPS
Brand NEW, GENUINE VW 4 BAR MAP Sensors. Ideal upgrade from the standard 2.5 or 3 BAR MAP sensor, as the standard 2.5 BAR will not read any more than 1.5 BAR (Relative). Obviously your car would be mapped to take into account the new sensor.
VW Part Number - - - 03K 906 051 (03K906051)
Bosch Part Number - - - 0 281 006 060 (0281 006 060) (0281006060)
These are 50 Posted on their own, or 55 with another order.
GTB Turbochargers
These are probably the Ultimate Street Turbo for the 1.9 TDIs.
The GTB2260VK, GTB2056VK and GTB1756VK are more or less identical visually, and will all interchange. So, for example, you could upgrade from a GTB1756VK to a GTB2260VK just by changing the Turbo.
I have New, Reconditioned and Used GTB2260VK and GTB1756VKs IN STOCK and Ready to go. All can be converted to Vacuum with OEM Parts, looks like a factory installation. GTB2056VK turbos are almost impossible to source BUT I have one in stock, once it's gone I don’t know when I'll get another.
A new GTB2260VK inc Vacuum Conversion is 935 GBP Shipped
They are listed here - http://www.darksidedevelopments.co.u...onversion.html
We also produce several turbo kits for the TDI Engines, the most popular being our 1.9 8v Kit - http://www.darksidedevelopments.co.u...i-engines.html
We also have a kit that will be released shortly for the 2.0 16v Common Rail Engines:
Keep your eyes peeled for the results of the testing - http://forums.tdiclub.com/showthread.php?t=367577
GTB Turbo Flange Adapter for Longitudinally Mounted TDI Engines
Fits ALL VW Passat / Audi A4 / A6 and Skoda Superb Vehicles with the 1.9 and 2.0 TDI Engines
This kit consists of:
Darkside Developments Waterjet Cut GTB Turbo Flange
4 x Allen Cap Head Bolts
2 x Countersunk Allen Head Bolts
This flange adapter bolts directly on to your existing Exhaust Manifold to allow the fitment of the Garrett GTB Series Turbochargers (GTB2265VK Hybrid, GTB2260VK, GTB2056VK and GTB1756VK) to your VW Passat, Audi A4, Audi A6 and Skoda Superb. These turbos are tried and tested on the VW Group TDI Engines and have been proven for reliability and power far above any Hybrid turbo.
Please see below for more photos of this flange fitted to a manifold and vehicle.
This flange will require your existing Exhaust Manifold to be post matched to get the best gas flow. This can be done very easily with a Dremmel or Die Grinder.
These are 48 inc Shipping Worldwide.
We can also supply GTB Turbochargers, Downpipe Flanges, Port Matched Manifolds, Oil Feed Lines, Vacuum Actuator Conversions and other parts required for this conversion. Please PM me for details
These are IN STOCK and Ready to Dispatch.
MADE IN THE UK
Please note - this adapter will NOT fit in transverse mounted engine bays, such as the VW Golf and Audi A3.
Fitted to a Passat/A4 1.9 8v AWX Manifold (Manifold available seperately for 100)
Fitted to an Audi A4 1.9 8v AWX Exhaust Manifold with a GTB2260VK Turbocharger and Darkside Developments Oil Feed Line (Turbo, Downpipe Flange, Manifold and Oil Feed Line available seperately)
Most of our range of TDI Parts are listed on our website - http://www.darksidedevelopments.co.uk/
I can take payment by Bank Transfer, Credit Card through my website (2% charge to cover fees) or PayPal (4% charge to cover fees).
Delivery times with DHL Express are normally 24-48hrs across the US, Canada are 48hrs but can be a little longer due to Customs.
Thanks for looking!
Ryan
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline
Old October 21st, 2010, 09:48   #3
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
PM sent...
'01 Jetta GLS, 5 sp, Black on Black, Leather, Sun Roof, MFSW, Monsoon, Cold Weather Pkg., Full LED interior, always a work in progress
FlyTDI Guy is offline
Old October 21st, 2010, 10:15   #4
ryanp
ryanp's Avatar
BRM Turbo Upgrade
http://www.darksidedevelopments.co.uk/products/vw-caddy-1-9-tdi-8v-pd105-bls-brm-200bhp-turbo-upgrade.html
This will be a bolt on upgrade for you guys with the BRM engines, I've fitted a few of these to Caddies with the BLS engine (our BRM basically) and they work a treat, one customer claimed 190WHP but i've not seen the dyno printout
We can do a good deal along with some PD150 injectors
RANDOM PARTS SALE:
12mm pump-
Its based on an 11mm body with a Genuine Bosch 12mm head and lots of internal upgrades. Has plenty or fuel for any size injectors, i had these running with .341's (below) and it ran sweet at part throttle and toasted the tyres at full throttle with minimal smoke (until i turned them up!! haha)
The pump has done around 1000 or so miles since being built
Ideally requires a new plug as i broke the connector when i was messing around. I'd like 1000 inc shipping, getting these built properly is not easy, willing to listen to sensible offers on all parts!!!
.341 injectors-
These have at most 200miles on them, i ran R520's before (below!!) I maxed the R520's out and these were installed for 1 dyno run and a bit of tuning before the engine was parted out. They were fitted to brand new bodies, I'm asking 550. No need for core returns but 50 will be credited if you do!
I made 280hp easily and one customer has 314hp with an 11mm pump!!!!!
R520's on Bodies
These are only 800miles old and ran perfect, only changed due to upgrade to .341's above. The R520's and 12mm pump are good for around 280hp according to my last dyno.
I'd like 350 for these
I'll have more stuff to list shortly, T4 pistons and custom H beam 1z/AHU rods
ryanp is offline
Old October 21st, 2010, 11:43   #5
FlyTDI Guy
FlyTDI Guy's Avatar
Nice! replied...
Old October 26th, 2010, 10:58   #6
glitdi
glitdi's Avatar
bump for excellent vendor!
OCD Member #4
glitdi is offline
Old October 28th, 2010, 10:19   #7
ryanp
ryanp's Avatar
Thanks man!!!
ryanp is offline
Old October 28th, 2010, 11:04   #8
FlyTDI Guy
FlyTDI Guy's Avatar
I gotta say, ordered on Friday, arrives on Monday from half-way around the world. Awesome. I can't even get stuff from one state away that fast. Two thumbs up for ryanp.
Old October 28th, 2010, 16:37   #9
glitdi
glitdi's Avatar
Paid for my parts on Tuesday, its Thursday and they are already waiting at my door.
Thanks Ryan! I don't think a commercial flight would get me there faster.
OCD Member #4
glitdi is offline
Old October 30th, 2010, 04:23   #10
ryanp
ryanp's Avatar
Haha, I dont think it would! I think if I come over next year, I am just going to get someone to stick me in a box and post me with DHL Express!
I have updated the post above as I have just got some Brand New 3 BAR MAP Sensors.
Cheers
ryanp is offline
Old November 8th, 2010, 02:30   #11
ryanp
ryanp's Avatar
Just updated the availability of the PD150 Turbo's - I have 2 IN STOCK, ready to go.
I can also get Brand New GTB2260VK, GTB2056VK and GTB1756VK Turbos, PM me for Details!
Ryan
ryanp is offline
Old November 8th, 2010, 19:58   #12
hwyroller
Ryan- Your 6 speed final drive ratio chart has me confused, because it has final drive ratio 1 and final drive ratio 2. How do you tell which ratio is with which trans code?
Which 6 speeds do you currently have for sale?
Also I wondered if you could find a ECU (ECM) for a AFN engine that would plug into a USA harness for a 96 passat 1Z car.
hwyroller is offline
Old November 9th, 2010, 01:39   #13
ryanp
ryanp's Avatar
I can get hold of the AFN ecu's, not sure on cost as it's a while since i bought an ECU! PM me for pricings, i'll need to erase the Immobiliser for it to work on your car.
The gear ratio chart is easy and confusing at the same time, the 02M gearbox had 2 final drives, one for 1st to 4th, the second for Reverse, 5th and 6th. You cannot add the ratios for these gearboxes into any normal calculator because of this, i normally do 3 gears at a time and merge them together. The ratio's are in the same column as the Sub-code. I'll be making a new chart soon with more infomation and comparisons to the 5 speeds.
hope that helps!
Ryan
ryanp is offline
Old November 13th, 2010, 11:39   #14
NewTdi
Fuel Economy: 52/47/39
Ryan, I finally got around to opening the goods you shipped to me on Septermber 9th. Thanks for the great products and great care you took in packing everything. If you could have only cleaned the EGR and intake manifold out to look new ... Hopefully its all going to go in before the end of the year!
RC3+, Sprint 520 (PP764 ready to go) 3bar map, VNT17, VR6/G60, SMIC upgrade, (1.8T pancake ready to go)
303,00 miles and counting!
NewTdi is offline
Old November 13th, 2010, 12:42   #15
ryanp
ryanp's Avatar
I would still clean the intakes myself but i was doing so many my neighbours complained about the mess on the street from the Jet Spray!!
It's not a long job for one but 10+ take a long time! lol
I'm still looking for a shop to do them at a reasonable price!
Let me know how fitting goes!
Ry
ryanp is offline
Closed Thread
Page generated in 0.21314 seconds with 10 queries
[Output: 144.26 Kb. compressed to 122.10 Kb. by saving 22.15 Kb. (15.36%)]
