Old June 16th, 2018, 01:29   #16
billy.whizz
TDI(s): golf mk6
yours should have started a regen by now ,if the soot load gets too 24mg and onwards then you have a problem. in the uk version soot load of 20/21 starts a regen and also the pressure reading pre and post dpf would control this as well ,engine temp, has too be normal working level ,if you have other related faults then these could stop it doing a regen. if you look at my readouts then that will give you an idea of whats happening,an auto scan will show any faults and mil codes . the fact that you can manualy perform a regen suggests that maybe other faults are not stopping it !!.
billy.whizz is offline   Reply With Quote
Old June 16th, 2018, 09:11   #17
mbesemann
Looks like I spoke too soon, after my last drive today it finally did a regen. Weird that the soot went that high, maybe the conditions weren't right on my previous drive.
mbesemann is offline   Reply With Quote
Old June 16th, 2018, 12:48   #18
billy.whizz
TDI(s): golf mk6
im glad its regened for you ,phew relief , I would think that if you had done some short drives and it never got too full temp the soot just got that high. keep an eye on it and see what happens next time .
Old June 17th, 2018, 00:32   #19
Henrick
Never worry about a regen unless you get the DPF icon on the dash.
Once it's there, take it to the highway immediately, it should regen.
If something goes wrong, it will trigger a CEL.
Once you have a CEL, then stop, it's time to worry and investigate things using VCDS. But before that I'd really advise not to try to "tune" some settings.
Henrick is offline   Reply With Quote
Old June 17th, 2018, 07:19   #20
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Originally Posted by mbesemann View Post
Do you think they’ll be able to see you tuned it in the past?
Yes they can tell.
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Old June 18th, 2018, 12:16   #21
piotrsko
piotrsko's Avatar
Fuel Economy: 46 city/56 hwy so far wonder what the Golf gets
Don't know if they can tell, but the ecm keeps track of "revision" changes that happen every time you change the software.
Hint: there should be no reason that you have 15 software changes logged.
piotrsko is offline   Reply With Quote
Ash load 2010 golf tdi vwman2 TDI (Diesel) Emissions 13 April 20th, 2015 05:03
DPF ash load upper limit for Q7 TDI? gdorris TDI (Diesel) Emissions 2 October 24th, 2014 13:25
30K service and DPF ash load check MKT VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 17 October 20th, 2014 09:57
Non VW 507 spec oil and DPF ash load. k^2 Fuels & Lubricants 25 May 14th, 2014 07:29
need someone to scan ash load in Mass jbbnet OBD Scanners 1 February 25th, 2014 09:37
Page generated in 0.16090 seconds with 12 queries
[Output: 75.67 Kb. compressed to 66.56 Kb. by saving 9.11 Kb. (12.04%)]
