Old May 18th, 2018, 07:04   #1
PickleRick
PickleRick's Avatar
Default Plastic elbow in clutch master feed tube
So I crapped the bed on this one. While removing all the 5 speed components on yet another v6 5 speed donor car i broke the plastic fitting. Is there a vw pn for this elbow? If not shes gonna get a brass or stainless 90 elbow and ill call it a day. I don't think dot5 eats brass? Ill have to double check that.
Weddings are basically funerals with cake
PickleRick is offline   Reply With Quote
Old May 18th, 2018, 08:21   #2
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Stainless you should be fine.
That little elbow is not available separately from what I recall.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old May 18th, 2018, 09:10   #3
PickleRick
PickleRick's Avatar
Stainless it is. I kick myself for forcing it out. Was 90 degrees and was tired of fighting it.
Old May 22nd, 2018, 23:26   #4
rocketboy52
rocketboy52's Avatar
I broke mine too, I ended up buying new master cylinder, it came with the elbow. The elbows has a couple of features that lock it into place in the fire wall. Without those features there to hold the feed tube, I will be a real stinker to try and mount the hose on the engine side of the fire wall. Good luck.
2004 VW Passat GLS TDI 221k
1999 F250 7.3l Powerstroke 283k
DIY Chainless Since 11/2011
rocketboy52 is offline   Reply With Quote
Old May 23rd, 2018, 00:42   #5
PickleRick
PickleRick's Avatar
That shouldn't be an issue as the barbed elbow doesn't rest locked on the mount. Slide the feed tube into fire wall from under hood, attach hose to barbed fitting then cut your reservoir nipple off, attach to reservoir. No different than assembly with oem fitting only less work to get in place.
99.5 ALH intake rubber elbow, plastic intake pipe to intercooler other misc offer SuperDave Private TDI Items for Sale/Wanted 3 August 23rd, 2011 16:38
ALH upper intercooler to EGR elbow tube! 1tdi Upgrades (non TDI Engine related) 1 July 18th, 2011 10:14
Orientation of Plastic Elbow on upper rad hose Uncle Milty TDI 101 2 January 24th, 2010 13:54
Pella plastic tube Monkey1 Fuels & Lubricants 6 November 28th, 2007 09:04
STRANDED--Need Part turbo oil feed tube in Milwaukee glenn1179 Private TDI Items for Sale/Wanted 1 July 2nd, 2007 21:39
Page generated in 0.11516 seconds with 12 queries
[Output: 69.90 Kb. compressed to 61.63 Kb. by saving 8.27 Kb. (11.84%)]
