Old May 17th, 2018, 21:50   #1
jrm
Fuel Economy: 42/52
Default oil seals covered by the dieselgate ext?
my extended warranty for the scandal extends to 142,000 miles- I have a oil leak somewhere inside the t belt housing, loosing a half quart every 5k.... but a mess under the car- does this cover seals? I see it covers everything the exhaust touches but not much on other items
Thanks, Joe
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old May 18th, 2018, 04:27   #2
Rico567
Probably only one way to find out for sure— go to a dealer and try to claim it under warranty. You should find out soon enough, without wondering. It's sort of like "pre-approval." And since you know where the leak is, you might not have to incur a "diagnostic fee."
I wasn't too thrilled at first with our new health care insurer having to pre-approve some procedures, but getting it in writing is a lot better than getting an unexpected bill for a $2K MRI.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old May 18th, 2018, 04:44   #3
d2freeman
Mine is at 221k and I also have a small oil leak, but seems to be from the back side of the engine, just a small drip, not enough to worry about yet. Also got a letter yesterday that the extended warranty has been extended for an additional 36m/3k miles, so 51m/51k total.
d2freeman is offline   Reply With Quote
Old May 21st, 2018, 01:29   #4
adam4584
the turbo drain line on mine was leaking and wasnt covered. under the tdi extended or the extended that i got from the dealer, but YMMV. just have to go find out
adam4584 is offline   Reply With Quote
EGR covered in oil/soot? Busguy71 TDI 101 7 February 27th, 2009 08:03
Oil covered coolant bottle fedxr VW MKIV-A4 TDIs (VE and PD) 3 March 20th, 2008 03:59
Oil covered EGR jaca TDI 101 10 May 26th, 2007 09:41
My car is COVERED in hydraulic oil snowball General VW Discussion 8 June 26th, 2003 09:45
Oil Covered MAF FLITZENFLEIG VW MKIV-A4 TDIs (VE and PD) 14 November 15th, 2001 10:14
Page generated in 0.11640 seconds with 12 queries
[Output: 63.07 Kb. compressed to 56.50 Kb. by saving 6.58 Kb. (10.43%)]
