Hi all,
I have a 2005 Passat B5.5 1.9TDI. I'm experiencing some brake issues exactly as discussed in this thread:
https://forums.tdiclub.com/showthread.php?t=162913
I lose vacuum boost after a few brake pedal pumps, so i've deduced that there is a leak somewhere. Unfortunately I can't hear any air leaking into the system, but I have found a 'loose' hose where the vacuum hose meets the vacuum pump. There is visible play where this hose meets the metal housing of the vacuum pump so I thought this would be a good place to start.
In order to investigate, I cut off the factory pressed clip with the intention of measuring the short section of hose so i could replace it. The whole piece can be bought online but the harder vinyl hosing which goes towards the brake servo seems in good condition so I only wanted to replace the small piece of rubber hose right next to the vacuum pump.
However, after removing the clip I realised that the play is actually from however the hose is connected into the vacuum pump. It seems like the hose is clamped onto a metal insert. I reattached the hose with a clamp and left it.
Can someone tell me if this is normal/a problem? If it's an issue and a likely source of my vacuum leak, how can I tighten it up?
Unfortunately having trouble uploading photos - the pics website is not recognising my login details so I can't upload a photo, so here's 2 links to them:
https://photos.app.goo.gl/TJT3y2TJjRvBWNfcA
https://photos.app.goo.gl/kumDEaEkaUsdoRS7A
Thanks in advance!
Thanks in advance!
