JSWTDI09
1) Nothing rattles all over the place. The filter bracket is securely attached to the stock fuel filter canister. Nothing moves or rattles. Zip ties are not required.excellent, that seems easy enough, thank you. I saw the previous versions, I plan on doing that, what should I do to keep it from rattleing all over the place? would a couple of zip ties do (interlocking two, one around the stock and one around the post filter)? also, the filter there looks like a normal gas engine oil filter, should the rubber gasket be wet with oil like when doing an oil change?
2) the filter is either a 1 micron or a 2 micron spun glass filter (your choice). These filters are actually the filters that are designed to go on "gas" station fuel pumps. They are approved for gasoline, diesel, and biodiesel fuels. They are actually designed to be fuel filters not oil filters. Yes, they are spin on type filters and yes, you should probably wet the gasket with fuel before installing. However, the manufacturer of the filters does say that the gaskets are "pre-lubricated", but I would still use a wet finger and put some fuel on the gasket before installing the filter. The gaskets are pretty good. It does not take a lot of force to get a leak free seal.
Have Fun!
Don
