shizzler
Hey everyone.
Some reading over at ecomodder.com has me wondering why no one goes all out making an alh TDI into a max mpg machine. I am tempted myself. Maybe its because without even trying we all get 45 or better...ha!
I decided to start with a simple grill block. Came out pretty good I think. Used a piece of black coroplast I found laying around at work and some small brackets. For those unaware of this mod, the point is to smooth airflow over the car and thus reduce the amount of aerodynamic drag. Second benefit is much improved warm up times for the engine, also a huge benfit to FE of course.
I also pulled the upper grill and blocked it also, with a small rectangular box feeding directly into the engine air intake on the upper right side. Don't have a good pic of this at the moment. Need to some rubber bulb seal along the front hood line to finish everything off.
Before anyone yells at me, I know, the 17's have to go. Soon I'll put on the stock 15's with winter tires, and come spring I will invest in some lightwieght 16s and slightly oversized LRR tires.
Besides that I may go as far as making rear wheel skirts and doing a passenger side mirror delete. A rear deck-lid extension like you see on bonneville salt flats max speed vehicles would be awesome also, but I don't have those kind of fabrication skills.
Something along these lines could yield an easy 70mpg from the most frugal hypermiler on these forums, I'm sure!
http://www.blogcdn.com/www.autobloggreen.com/media/2007/08/fusionhydrogen999_2.jpg
So who else has gone down this path? Let's see some photos of your aero-mods!
