c.Lunn
I bought this car for a donor for a MK1 swap.
The metal shards pictured were found in oil when it was drained and in pan when it was pulled. Shards are ferrous.
The odometer reads 250,000 https://imgur.com/a/RgLdzcm . Seller claims the car was tow behind a motor home most of its life. The seats and pedals do not look worn like there is anything close to 250,000 miles, but I am a skeptic in all things unverified.
Oil was in intercooler.
Car idled, started and drove normally.
I would appreciate input into what you all think would cause this lifter problem, or if it is normal for an ALH to need a cam/lifters with a few hundred thousand miles (assuming it was towed 50,000)
When a ALH goes in the MK1 I want to have confidence I can drive across country if I want.
I am open to all options...
Rebuild from crank up, sell it and find something else, or replace the cam and drive it.
I dont want to spend money I dont have to, but I also dont want to have reliability issues when it's all done. I would like to be able to put 150,000 miles or so on it.
Can I pull the main caps and rod bearings one at a time to inspect the bearings. Will that cause any problems? Can I just retourque them and all is well?
If anyone has a suggestion for a detail oriented TDI engine builder in the mid west I would appreciate it. I'm possibly looking for builder-not interested in big power, but reliability.
Thanks for any help!
Clint
Clint
