mextdi
- Joined
- Dec 16, 2013
- Location
- Saint Paul, Minnesota
- TDI
- 2006 Jetta TDI 1.9, 2012 Passat TDI SE DSG, Previous 2014 Beetle TDi, 2012 Golf TDi DSG
Howdy!
My 2006 Jetta TDI DSG has about 230k miles on it. In the past 1k miles I have replaced the camshaft, lifters, timing components, DMF, head gasket.
After the most recent service, which was the head gasket, I started seeing P0101 come up. At first I discovered the hose to the turbo to be loose, my mistake, the one from the air filter. Then I replaced the MAF sensor, and it still came up. I had a tuned out EGR, so I reflashed the non-tuned image thinking maybe it was an EGR conflict of sorts. P0101 is still coming up and I am not aware of any loose connections. When I had the head off, I cleaned the intake and EGR valve as best as I could and checked the turbo wheel for play, no play. It comes up after about 20 miles of driving in mixed conditions, light traffic and highway driving.
I am out of ideas.
I have a Vagcom so can run logs and such, can someone tell me what I would be looking for and which tests to run for this error?
I am out of ideas.
