diesel4ever
Car is running OK, but the temperature gage reads about 70C deg (158F), which has been confirmed with ScanGauge II. I have removed the bottom cover (skid plate - damaged) and disabled EGR cycle. During summer the temperature will reach normal temperature. Is there 'too much' cooling because of so much draft through the engine compartment in winter months and is the engine going to be affected in any way, long term? Is there perhaps different thermostat that would be able to compensate for this? It takes forever to get any significant heat to passenger compartment when the outside temperature is bellow 0C deg.
