The car starts perfectly. The first 3-5 miles down the road it runs perfect, then it doesn't have enough power to pull the hat off of your head. I've changed the air filter, no change. Changed the fuel filter, that got me 10 miles down the road, same problem. When it isn't running right I put a manual vacuum pump on the turbo, no change. On a different test drive, 3 miles into it, same thing again, I shut it off for 5 minutes, then it ran perfect again, but still acted up. It doesn't matter if its cold or warmed up. Do these cars have a transfer pump in the tank or some where else? It just seams to me that I"m not getting a constant flow of fuel to the filter/ injection system, thus when I first take off its fine and then it acts up.
Your advice is very welcomed.
