Tech sessions schedule?
turbinia2
Chicagoland IL USA
2001 Jetta, baltic green
Do you (will you?) have a list of tech session topics & times for the DIY maintenance sessions, at Topels on Sat morning? Trying to figure out if I can do that traffic cone crunching thing
and still learn the techie stuff at practically the same time.
eschady
Milton, WI
2003 Jetta GL Black w/gray int.
Timing belt will start around 8am and will go until around noon probably as it is a long procedure.
Intake cleaning will be similar, starting 8-9ish and running until around noon.
Shocks and struts will be from 9-noon.
Basic maintenance will be between 9-11ish.
So there should be time to run over and do the slow speeds skills competition.
