Comesummer
Headlights and Dashlights started to Pulsate going from normal to dim about every second. It is consistent and you could set a beat to it (not random). It does it at idle and high RPM and stops pulsating every once in a while. It is very noticeable in the headlights as well. Now the Climate control is acting strange going to slow speed to high and not working at all at times. Thinking it is a grounding issue, does anyone have an idea what would cause this and where the ground would be for the Climate Control? Thanks
