2006 Jetta TDI (PD - Think it's actually a 2005.5).
I've read at least 5 threads on the P0101 error.
My problems started about a month ago when I got errors for the glow plugs. I replaced glow plugs (about 2 yrs old) and also replaced the air filter. Within about 15 minutes of driving I got error code P0101 code and the engine sounded really rough with lots of air noises. No noticeable power loss. I changed the MAF sensor and the vehicle still shows P0101 code after a day or so of city use.
1. I replaced the camshaft about 14 months ago because of an unrelated problem.
2. I can unplug MAF while engine running and the engine continues to run.
Not sure where to go from here. Reading some other threads, looks like next choice might be to look for air leaks. HOWEVER; the fact that it continues to run after I unplug the MAF tells me there is an electric problem. Any idea?
