hymato
I just had my BRM rebuilt top to bottom and was wondering opinions of running high zinc oil for a few thousand miles.
Old school nonscence and the OP was asking about extra ZDDP for the break in. Not when to change the oil.I'd change out the first oil out way before a few thousand miles myself.
No, it's unscented good sense! . This is a rebuilt engine. Do you think VW runs their initial fill for several thousand miles or equivalent at the factory?Old school nonscence and the OP was asking about extra ZDDP for the break in. Not when to change the oil.
But from what I understand VW factory fills the engine with oil runs it for a very short time, not a couple thousand miles. Drains it, then fills it with the oil you recieve when you buy the car that you leave in for 10K. This still doesn't answer the original question about zinc.The OP was asking about extra ZDDP for the break in. Not when to change the oil.
That sounds like a good procedure. I would do something similar.I used Joe Gibbs BR break-in oil. It is a very high ZDDP oil, but lacks detergent, or any other additives. It is designed to break in cams and seat rings quickly. Two 500 mile runs of this oil is what I would do. The oil should not be used in longer intervals since it has no detergents or additives to suspend soot.
This was what I did on my 2003 Wagon engine listed in my signature. Results have been excellent.
Ding, Ding, Ding! I think we have a winning answer for the OP. Hope he is still following this thread.I used Joe Gibbs BR break-in oil. It is a very high ZDDP oil, but lacks detergent, or any other additives. It is designed to break in cams and seat rings quickly. Two 500 mile runs of this oil is what I would do. The oil should not be used in longer intervals since it has no detergents or additives to suspend soot.
Don't play Chemist you may throw off the ideal balance of additives in the engines oil which are already beyond sufficient!I just had my BRM rebuilt top to bottom and was wondering opinions of running high zinc oil for a few thousand miles.
XXw30 is too thin for Flat tappet PD engines!Has anyone tried the Rotella T5 10w30 semi synthetic or Rotella T1 SAE Straight 30W (known to be high in Zinc). I hear those work if you use some Redline 81403 additive.
Just use the Mobil 1 Turbo Diesel Truck 5w40 and run it 15,000 miles.
15W-50. I disconnected the fuel-cut solenoid during cranking prior to first start until I had full oil pressure and oil coming from disconnected turbo oil drain. Then I buttoned everything up and started the engine.15w 40 ?
