Why? What's the benefit of adding one?Yes, I would like to add one.
same thing happened to me on my '04 .... at work ... had to get a tow to get homejust an FIY. if the pump dies..the car will stall and will have a hard time starting back up. wont throw any codes either.
happened to me and thought it was the injection pump....turned out to be the lift pump
when i installed my lift pump in my ALH, i did the whole bypass tube mod on it as well.On a BEW, yes, you could be left stranded if it fails. But not with an ALH (if you use an OEM pump with the bypass tube present). The injection pump will still pull fuel from the tank. The lift pump is there as a helper to get more fuel to the IP at high RPM.
