trueblue88
I've done some searching on the threads regarding this fault but can't find one that is similar to mine. The car has no boost of course. I applied vacuum to the actuator and verified that it moves. Performed basic setting in mvb 11 and the rod does not move. I switched the n75 with the egr valve and same thing. I don't even hear it turning on. Found that it has power and the ecm is activating the ground. I even checked the wire from the n75 to the ecm and found .2 ohms. I know my dad replaced the valve on the brake booster hose because he thought it was causing the hard brake pedal after applying the brakes a couple of times. Can a lack of or no vacuum cause the n75 not to turn on ? Am I not hearing it turn on because there is no vacuum there to actually activate it ? I'm stumped.
