mrrhtuner
- Joined
- Mar 29, 2011
- Location
- London Ont Canada
- TDI
- 2003 Jetta Wagon TDI, 2015 Passat TDI, 2015 Touareg TDI
Hello everyone,
Let me start off with the history of my 03 ALH wagon. When I was viewing the car, I was never informed of the current limp mode condition that the previous owner was experiencing. I took the car for a test drive and it seemed to drive fine.
Paid for the car and it was fine for a few weeks until eventually limp mode became present.
When the car was in my possession, I have tested the MAF, installed a fairly new EGR from my old car and replaced all the vacuum lines. I've also re-checked my turbo piping to IC and verified my turbo doesn't have any side to side nor in/out play as I was curious.
Initially the limp mode would only show itself in the colder temps, spring/fall/winter. But this year, I can get it into limp mode anytime.
I've looked at the code and it's the overboost condition error that is generated.
The actuator is fairly new, installed by a TDI guru not long ago when it was in the PO's hands.
This spring, I've experienced two incidents that really make me worried about something going horribly wrong.
Both incidences were in the morning, a few short KM's from home on my way to work. The motor was on it's way or was fully warmed up...I can't recall.
Both incidents, I accelerated quickly in traffic to change lanes or enter a side road.
What happened was...I'd accelerate and instantly after moving I'd see a large cloud of smoke. Upon seeing this, both times I've let off the gas and made sure my car wasn't going to experience a runaway turbo. Both times I've noticed that the car will idle really bad and it seems to be in limp mode.
This early week, it happened again (the second time) so I quickly parked it and got out to record what I can.
Here is shortly after it happened.
https://www.youtube.com/watch?v=Lt4AgL1ESyY
Here is the car after I drove it for a short bit (100 feet or so)
https://www.youtube.com/watch?v=_4mCsQJNyfc
So I am not sure what to do here. I car drives/idles perfectly fine otherwise as long as I stay out of the hard acceleration/boost area.
Could my turbo be somehow clogging up and suffocating the motor?
Any ideas?
Any ideas?
