Old May 12th, 2010, 16:43   #1
Mr Wizard
Default How Screwed Am I? Block Damage
How screwed am I?
Well guys, I just purchased a 2001 Jetta TDI. The interior and the exterior are in immaculate condition and I feel like I got a good deal on that.
Then comes the motor. When I test drove it it ran great and everything was perfect. I leaked a moderate amount of oil and I figured it was the head gasket that needed to be replaced. Damn I was wrong.
I saw in a few places there there have been issues with the boss breaking at the rear of the engine for the PS motor mount. Well, for me it ripped the entire corner off the block.
As of right now, one of the oil gallies from the head is open to the atmosphere. This is where the oil is leaking slowly from. When I add oil and direct it in that direction I can watch it flow right on back out.
First a few questions:
1. How good is the PCV system at keeping negative pressure? DOes it do well to keep it always below 1 bar absolute? This goes into the JB weld repair
2. I have not yet checked through the for sale section (I will), but how hard is it to come by a block?
3. Can someone confirm that the block is made of cast iron? Does anyone know any specifications for the material?
Repair Options. I have kicked around a few ideas. I do alot of work on my gas cars but this is the first experience with diesel.
1. Replace the Block. Heads seem to be fine
2. Replace the short block.
3. Remove the block and attempt a weld repair on the material.
4. JB Weld. Yes, I know, please keep the laughter at a minimum. The reason I am thinking about this is that the bock is not highly stressed in this area and all I am trying to do is keep the oil in the galley. I am not sure how I would secure the JB weld as I am not sure if it will bond to the material. I am sure some kind of prep would be required. Sanding, grinding, maybe adding some studs or something for the JB weld to grab onto. A secondary to this is to fabricate a piece of steel plate which will fit into the damaged areas. An opening would remain at the top to release any pressure.
I talked to the dealer where I bought it and they are willing to help out with the repairs... maybe. I have not gotten into specifics with them yet about what, if anything they will pay for. Here in florida there is no 3 day take it back period. Once you sign the papers its done.
Attached are some photos of the problem area.
Christian
Mr Wizard is offline   Reply With Quote
Old May 12th, 2010, 16:50   #2
Mr Wizard
The first two photos are the inside of the block:
Some photos of the outside of the block:
Old May 12th, 2010, 17:57   #3
ninedee_golf_tdi
You aren't the first person this has happened to, and won't be the last. It occurs because the horizontal bolt from the mount bracket to the block was torqued incorrectly or broke or ? The damage you sustained, imho, should be considered the end of the line for that block. While cast iron can be welded, the amount of work it will take to get the block ready to be welded would negate the benefit of trying to salvage it. That's assuming you have the missing chunk to weld back in place. I would just buy a new block and be done with it. I wonder who did the last timing belt on that car ?
Now that I think about it, you noticed this oil leak before you bought it ? Did you make mention of it to the dealership before you signed the papers ?
ninedee_golf_tdi is offline   Reply With Quote
Old May 12th, 2010, 18:11   #4
Mr Wizard
Before I signed the papers I knew there was a leak. I did not notice the broken block. I figured it was the head gasket or some other oil line and that it could be repaired. This is the first time that i have come across a block that was broken.
The thing is... According to the sales guy it was in the shop before the sale to replace some misc parts. He stated that the oil was changed. If this was the case then they knew there was a problem because when you put oil in, oil comes out in huge quantities.
Based on that I could probably have a good case to negate the contract. The thing is that I did get a good price for the car and the interior and exterior are in great condition.
Blue book for the car is 4600 but I have seen them sell with less options around town for around 6500. I got it for 4800.
My plan is to attempt a repair using steel plate and JB weld. At the same time I am going to work the dealer for some compensation.
The timing belt does not look bad. No frayed edges or damage to the rubber. If its anything like gas cars I would estimate 20-30k on the belt.
Christian
Old May 12th, 2010, 18:23   #5
dieseldorf
top post dawg
dieseldorf's Avatar
If this is related to a botched timing belt attempt, I'm willing to bet you have other clean-up matters to address.
Can you get your $$$ back?
Old May 12th, 2010, 18:23   #6
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
http://shopping.boraparts.com/produc...roducts_id=265
Why DIESEL is better: (Courtesy TDIclub forum member wxman)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
n1das is offline   Reply With Quote
Old May 12th, 2010, 18:33   #7
Mr Wizard
Dieseldorf: Its possible. I really don't know much about these cars other than what I can transfer over from my gas cars. If I asked for the money back the answer would be no. The only way that I could get it back is to take them to court and try to prove that they knew about this major mechanical defect and did not disclose it. I am not sure though that they are required to.
n1das: thats more than I paid for the whole car. I would probably go the route of selling the car as-is (disclosing everything), take the loss and buy another.
If it came to get a block, machining it, and then transfering all the parts, its not out of the question. That is not out side of the skill set.
Old May 12th, 2010, 18:36   #8
Mr Wizard
My first attempt at fixing this will be to do the following:
1. Disassemble the intake system.
2. Drain oil and remove oil pan.
3. Clean affected area with a degreasing agent.
4. Fabricate a rolled steel plate which fits into the broken area with clearance
5. Use JB weld to cover the hole.
This will not allow for the installation of the engine mount bolt but there is nothing that I can do about that. What it will do is stop the leakage of oil. Other than the oil dripping on the floor the engine runs great. The damage does not appear to affect the operating characteristics.
If this does not work or fails, then I have not lost anything other than a few tubes of JB weld and my time. At that point I can go ahead, get a block and tranfer all the parts.
Old May 12th, 2010, 18:37   #9
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
There are very few, if any, matters relating to TDI's where I would ever be tempted to disagree with ninedee_golf...
You can probably find a reasonably-priced engine with a bad cylinder head... (happens quite often as a result of a badly performed timing belt change...)
Good luck,
Yuri
(PS: I recently found a used engine for $400... had to transfer over most of the accessories, but my car's up and running...)
ymz is offline   Reply With Quote
Old May 12th, 2010, 18:41   #10
Mr Wizard
I agree with ninedee. A replacement block is the right way to go. As of this time though I do not have the budget or the time to do that unless absolutely necessary.
I work a decent amount with welding very old (30-40 years) casting and I realize that the weld option is unlikely.
I figured I would try to fix it first as a temporary (if it works, permanent) measure and plan on replacing the block in the fall when the weather is not as hot.
Can anyone answer the question about
Old May 12th, 2010, 18:48   #11
rackaracka
I'd attempt to get out of the deal if you can. It's a real shame that someone would try to sell a car to someone like this... If you got it for 2,000 then it would be fair.
2002 Jetta Wagon TDI Auto- Reflex Silver/Leather/Monsoon
95 Dodge 2500 w/Cummins TD - Straight piped 4 "
98 Beetle TDI 5spd - Herbie/11MM/VNT17/pp520/RC3/Mcnally Gauges/SBC2 Endurance/Bilstein HD's/Dieselgeek Panzer FMJ/3" Kerma turbo back
rackaracka is offline   Reply With Quote
Old May 12th, 2010, 18:57   #12
Mr Wizard
I know. I was thinking about using the fact that they had to know about the damage as leverage to get it fixed. I could push them to take the car back or have the mechanic pay the repairs, but I do like the car.
I have been in contact with them regarding the issue but have not pushed them yet.
They are going to send me the receipts for the repairs which were performed before I bought the car. As stated, part of this was the oil change. If a oil change was performed there would have been obvious evidence of the damage. I want to get these receipts before doing anything else so that the don't get "lost".
Old May 12th, 2010, 19:01   #13
Mr Wizard
Also, just to clarify. This was not a serious dealer. This was more along the lines of Joes used car lot.
I have been looking for a decent one of these with the options that I wanted for the last 2 months. So far this was the only one that I have found within my price range.
Old May 12th, 2010, 19:05   #14
ninedee_golf_tdi
I just have to believe the car was parked around the corner from that car lot, then a few cans of brake clean were used to wash the block free of the oil, the owner tossed the keys to the lot bubba and ran. Any chance of tracking that owner down for some maintenance history ?
Old May 12th, 2010, 19:07   #15
Mr Wizard
Unfortunately no. The car is Canadian. It was traded in to a Mercedes dealership in Gainesville who then sold it to the used car lot where I got it here in Orlando.
As far as I can tell, the dealer in Gainesville registered as required and then immediately sold it. According to the carfax it was never registered anywhere else in the US.
Page generated in 0.17569 seconds with 10 queries
[Output: 123.08 Kb. compressed to 102.95 Kb. by saving 20.13 Kb. (16.36%)]
