Old December 29th, 2015, 11:19   #1
Shenandoah
Default 2002 Golf 4 door TDI into a 2000 Golf 2 door gas
Folks,
Unfortunately one of my 2002 Golf TDIs is totaled. I bought the car from the original owner and it only has 165,000 miles on it. Last month I picked up a very nice 2000 Golf 2 door (gas) with a manual transmission. Body is in great shape, interior can be cleaned up to be nice. Motor has a hole in the block where it threw a rod.
I think I'm going to attempt swapping the ALH from the 2002 in to the 2000. The 2002 has an automatic, but I have a TDI manual trans from when I switched my Beetle to a 6 speed. The 2000 has a manual, so clutch pedal is already there. Both have manual windows. Taking a quick look at the engine harness, I think I only need to pull the ECU harness from the TDI and swap it with the gas harness? I've got to check where the glow plug harness is as I cut that off for one of my other TDIs. I'll also have to switch the "gas" pedal as the 2000 is not drive by wire. I'll also have to look at the gas tank/fuel lines on the 2000 and swap them with the 2002 if needed.
For those of you that have done this, is there anything I need to separate out from the ABS/fuse panel harness? I'm sure I'll have to check relays and what not.
We'll see how this goes.........
Eric
Seven TDIs: 2005 Jetta Wagon; 2005 New Beetle; 2004 Jetta; 2002 Golf; 2002 Jetta Wagon; 2000 Audi TT; 1999 New Beetle
Three Gas: 2000 Golf; 2002 Jetta; 2003 Jetta
Four "parts" cars: 2000 Jetta; 2000 Beetle; 2002 Golf (two of them)
Shenandoah is offline   Reply With Quote
2002 2-door Golf CA $2000 TDi Newb TDI Cars for Sale/Wanted 4 April 5th, 2012 11:18
2010 golf tdi gas door baglenn VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 September 8th, 2010 10:32
WTB: Rear Parcel Shelf for Golf IV (2000 VW Golf GL TDI 2 door) cdroadwarrior Private TDI Items for Sale/Wanted 3 August 2nd, 2007 21:52
2 door vs. 4 door Golf TDI Gas Mileage styhurs TDI Fuel Economy 10 March 21st, 2007 19:36
2000 Golf TDI 4 door ob1kobi TDI Cars for Sale/Wanted 3 November 16th, 2003 21:27
Page generated in 0.11161 seconds with 11 queries
[Output: 48.12 Kb. compressed to 45.36 Kb. by saving 2.76 Kb. (5.74%)]
