Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > New Beetle TDI Picture Gallery
New Beetle TDI Picture Gallery Do you have a New Beetle TDI? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old May 22nd, 2015, 19:03   #31
str8t six
str8t six's Avatar
TDI(s): 2001 GLS TDI
Fuel Economy: 47mpg
what wheels are those??
2001 Jetta TDI 5spd. Malone stage 1.5 tune, HFLOX Warp stage 2 nozzles, Mufflerectomy, Short shifter,
Black headlights, B-pillars, roof, grille, and taillights, Panzer skid plate,
Eibachs Pro springs, MB motoring Seven wheels, GT Altimax HP 225/45/R17.
str8t six is offline   Reply With Quote
Old May 23rd, 2015, 09:24   #32
Kingcodez
TDI(s): 00-Beetle
Fuel Economy: 45 MPG
I really want to build those front and rear guards, do you have CAD files or do you have a price to duplicate them? Beetles are cheap so I figure I'll stick with my platform & engine for a few more years until I find a nice AWD unit to swap in.
Kingcodez is offline   Reply With Quote
Old May 27th, 2015, 17:08   #33
GIDDY_UP_GO
Fuel Economy: 39mpg (But I drive 80mph alot!)
Oh yeah, I also love the pictures of the Sherriff deputies checking out your ride. They didn't give you a ticket or anything, right? Just admiring your car?
2004 Jetta TDI 183k mi
2010 Jetta TDI 155k mi (Fix Completed 12/17)
2015 Jetta TDI 40K mi (Did the buyback on 2/17)
2015 Golf SportWagen 4000 mi
THIS WILL MAKE YOU CRY!
GIDDY_UP_GO is offline   Reply With Quote
Old May 28th, 2015, 17:55   #34
Colin Doyle
TDI(s): 00 Beetle
The car rides on Basset ministock wheels.
The deputies were just checking out the car.
No CAD files, just my eye, a tape measure, and a bender. I usually quote people $50 per bend and $20 per weld as a baseline for a bumper build.
Colin Doyle is offline   Reply With Quote
Old June 3rd, 2015, 13:48   #35
cbalthazor
Any pointers on how you attached the bumpers to the front and rear of the car. I am going to do this on my 04 wagon, just timid on where to mount that won't interfere with the airbag sensors and crap. Also, since it's a jetta platform car, going to probably need to trim the existing bumper to keep part of it as it covers so much of the front end of the car.
Guess I could just do sheet steel as a skin with mesh grate to help protect important parts.
cbalthazor is offline   Reply With Quote
Old June 3rd, 2015, 23:17   #36
Colin Doyle
TDI(s): 00 Beetle
The airbag sensors weren't a concern, as this car is a prior salvage and the airbags were inoperable from the day it came into my possession. It has an Audi A4 steering wheel now without a functioning airbag.
I mounted the front bumper on the stock impact absorbing shocks. In the rear, I cut apart the shocks and replaced them with sections of thick-walled 2-inch square tubing, which run deep inside the body's frame rails and bolt in from the sides, as well as utilizing the original flimsy sheet metal mounting points. I heavily gusseted the section between the (former) shock mounting plate and the bumper beam, retained the beam, and used it as a foundation for both the tube bumper and its integral receiver hitch. It's solid.
Old August 29th, 2015, 23:43   #37
Celco
Fuel Economy: ~41 average
Rad build there! Wish I had access to a welder again, thus wouldn't be such a pipe dream.
Celco is online now   Reply With Quote
Old September 11th, 2015, 17:30   #38
Colin Doyle
TDI(s): 00 Beetle
Thanks!
I don't even consider this a build. This is just a little outfitting of my daily driver.
Old October 2nd, 2015, 12:22   #39
jeepnguy
TDI(s): 2011 JSW
Originally Posted by Colin Doyle View Post
Hah, yeah right! Hood stack isn't really my style, but if it were I'd rather put it on my most recent project truck:
The ol' Ford-Cummins-Allison hat trick.
That's bad ass!!! I used to drive an '11 F-650 with the Allison/Cummins combo. That was a beast!! Does yours have the push button tranny?
Mine was #8, wanted to paint a black 8 ball on it, but they frowned upon it.
jeepnguy is offline   Reply With Quote
Old October 2nd, 2015, 20:01   #40
Colin Doyle
TDI(s): 00 Beetle
No, it's just a normal column shift. The pushbutton shifter for 1000- and 2000-series Allisons is really just a driver for a motor which turns the shift shaft, and doesn't have the diagnostic capabilities of the pushbutton shifters on the larger Allison transmissions.
I just got the F650 on the road this week, actually. I've been daily-driving it while I work a few kinks out of it. Really needs to be geared up a bit - I think the final drive is something like 5.57:1, so it turns 2500 RPM at 72 MPH. Exactly what you need to push a tall van body through the wind with a 200 HP engine. Now that's 300+ HP and cuts a smaller hole through the air, however...
Old October 6th, 2015, 16:45   #41
croppz
This thing is sweet dude, keep up the work.
croppz is offline   Reply With Quote
Old January 4th, 2016, 09:46   #42
Kingcodez
TDI(s): 00-Beetle
I still want these bumpers!
Old April 19th, 2016, 08:56   #43
Smokin Joe
TDI(s): 2006 Beetle
Mr. Doyle:
You have some serious fabrication skills. Congrats to you on an awesome looking rig. May I inquire what tire size you ended up with?
Thanks,
Smokin Joe
Smokin Joe is offline   Reply With Quote
Old September 24th, 2016, 14:17   #44
Colin Doyle
TDI(s): 00 Beetle
A few updates. I've been doing a lot of maintenance stuff: charged the AC, replaced the leaky o-rings on the oil cooler, replaced ball joints, replaced a caliper and master/booster, etc... Old car junk.
I got sick of the constant vibrations from the garbage Bassett steelies, at least one of which had a barrel which was not concentric to its own center bore. Found some 15x7 ET38 OZ gravel turbofans, had them powdercoated silver, and applied new decals to the faces. I coupled those to 38mm spacers to achieve the same effective ET0 offset of the Bassetts. Mounted the same 215/75-15 General Grabbers.
I also revised my lift strategy: I wasn't satisfied with the way the metalnerd-style spacer preloaded the front springs, and there wasn't really any better way to lift the car using the stock strut mount configuration. I got a pair of Mk5 Jetta front strut mounts, welded the Mk4 spring hats to the Mk5 components in order to center the smaller-diameter top coil, and fabricated a simple double-flanged spacer to bolt between the mount and the body. The spacers are about 1-5/8" tall, which resulted in approximately the same amount of lift I had previously. There was some seam-sealer inside the strut towers which needed to be removed with a wire brush on the angle grinder, and then I drilled three holes in each strut tower to match the Mk5 mount's bolt holes. I used the same Moog springs, which are both thicker and taller than the original Beetle springs.
In the rear, I built a quick fixture which bolted to the beam and marked the locations of the spring perches and shock mounts, then hacked those mounts off the beam. I elevated the spring perches about an inch, and moved the shock mounts up about two inches (the longer Moog springs required an unhealthy amount of preload before I was able to bolt in the shocks - even now, they need to be compressed a couple inches.) I installed the beam with new Cupra R bushings, a homemade anti-roll bar, and new Bilstein shocks/struts (all the way around.)
Car rides properly now, and handling is far more neutral than it had been previously. It was hard to get a gauge on the handling with my old setup because so many of the components were completely shot - e.g. the struts/shocks and bushings. It used to understeer badly, but now it holds its line and will lift-off oversteer. Should be fun in the winter!
Photo dump:
Pleased with the amount of rake it has - IIRC it measures 30.5" front and 31.5" rear at the fender lip. Should pull a trailer without dragging ass now.
Old September 24th, 2016, 14:23   #45
Colin Doyle
TDI(s): 00 Beetle
Oh, also: I recently took this car on an adventure to Texas. I purchased an M1088A1 at Fort Hood, so I built an A-frame tow bar with a lunette ring and affixed mounts to the Beetle's bumper.
A good friend of mine had purchased an M923-series 5-ton truck from a GovPlanet lot at Fort Riley in Kansas, but it had four flat tires. I dragged a little Harbor Freight trailer down there with good spares and a heavy tow bar, dropped it with our guy at the auction site, and continued south to retrieve my truck.
I returned a couple days later flat-towing my Beetle with the M1088, we reconfigured the load, and I got all three vehicles back home to Minnesota. Long drive at 56-58 MPH. Tow bars are fantastic.
00 beetle little to no heat stang66007 TDI 101 28 January 4th, 2011 11:14
Looking for some advice???00 beetle Beezman7 TDI Power Enhancements 25 March 12th, 2010 06:28
'00 New Beetle No Turbo solarmike TDI 101 3 July 25th, 2009 10:40
00 new beetle A/C problem wal1809 TDI 101 10 March 16th, 2009 09:53
'00 New Beetle TDI Carfunkel Private TDI Items for Sale/Wanted 3 April 30th, 2002 20:29
Page generated in 0.15816 seconds with 11 queries
[Output: 130.32 Kb. compressed to 109.97 Kb. by saving 20.35 Kb. (15.62%)]
