Old December 1st, 2010, 14:40   #1
stang66007
Fuel Economy: 55mpg+ at 65 mph highway
Default 00 beetle little to no heat
engine runs at operating temp but changed t-stat anyways. no change. I have little to no heat coming out off the vents. 130K on car. Do they have problems with the blend doors on these?
09 Jetta 5spd, Stage 2 Malone, 2 1/2" downpipe. still have a couple ALH's.
stang66007 is offline   Reply With Quote
Old December 1st, 2010, 14:41   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Ever noticed any black foam blowing out of any vents?
oilhammer
www.cardocautomotive.com
Old December 1st, 2010, 14:43   #3
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 46 now (2016)
There is a cable that connects the knob to the blend door. If the cable anchor at either end has come loose, then the blend door won't change position when the knob is turned.
-Rich
OH: Has the sound deadening in these been blocking things up?
574,500 miles now and counting...25,500 until cluster swap!
'00 Jetta GLS, '03 Jetta GL, 08 Highlander, '72 Plymouth Satellite, '68 Chrysler 300, '75 Benz 300D, 78 LeSabre Turbo.
Nutsnbolts is offline   Reply With Quote
Old December 1st, 2010, 15:04   #4
AndyBees
AndyBees's Avatar
If Rich is correct, it is a PITA to access those controls. May/June/July of '09, I did a write-up how to access the heater control system..... do a search and find it. Also, others have written some pretty good stuff on this issue!
'84 Vanagon '02 ALH TDI engine(32 to 35+ MPGs consistently) Malone Stage 1 tune. Road trip to Nova Scotia 2013. Road trip to Alaska summer 2014 & 2016, 11k & 12k miles. 80k miles on install, Jetta Cluster odometer currently at 209k miles.
AndyBees is online now   Reply With Quote
Old December 1st, 2010, 16:24   #5
stang66007
I looked under the dash & the cable seems to be moving the door both ways. I do have foam in the vents. It seems to blow out defrost, vents, and floor at same time.
AndyBees, I haven't found the writeup yet, but will keep looking.
I decided to try adjusting the cable a little also.
Old December 2nd, 2010, 05:20   #6
oilhammer
oilhammer's Avatar
You need a new center HVAC case... blowing foam is the smoking gun. That sucks.
oilhammer
Old December 2nd, 2010, 06:26   #7
stevekris
Sent you a PM. Thanks Steve
stevekris is offline   Reply With Quote
Old December 2nd, 2010, 14:47   #8
stang66007
Are the parts only available from the dealer?
Old December 2nd, 2010, 15:03   #9
oilhammer
oilhammer's Avatar
I have never seen anyone else carry the HVAC case. They are not that expensive on some cars, depending on if it is all one piece with the blower case or not. If it is all one piece, it costs more.
oilhammer
Old December 2nd, 2010, 18:39   #10
gt
Default Is it a manual or auto/tr.?
Manuals have 3 heater plugs on the end of the head. Auto/tr. cars don't use them. Could be bad relay or plugs, They are bigger than glow plugs that start the eng.
gt is offline   Reply With Quote
Old December 2nd, 2010, 18:58   #11
DanG144
This is correct information, but I do not think they will make a difference in this case.
It sounds as if he needs to replace the blend door foam. The doors are simply latticework and once the foam is destroyed, you cannot properly control the heat and AC.
Old December 3rd, 2010, 14:17   #12
jimbote
jimbote's Avatar
you can pull most of the dash, leaving the main part of it in place, unbolted, so it can be shifted...then you can remove the front defrost/floor duct...from there you have just enough room to access both blend doors and glue something to them.....I just did this job on a NB and it was a PITA!!...but I did not have to dump coolant or evac the AC system...I measured the blend doors carefully, cut some vinyl to fit and glued it vinyl side to the doors (fabric back out) ....my arms and hands were covered in glue but the end result was cook you out heat
Old December 3rd, 2010, 14:21   #13
jimbote
jimbote's Avatar
let me also add that another way to diagnose this (besides no heat) is that the blend doors will make a distinct metallic ring (blend doors are constructed of galvanized swiss cheese) when they reach the stop in either direction...after they are successfully recovered it dampens the sound
Old December 3rd, 2010, 14:22   #14
DanG144
And this is the same sort of story I have heard from several people who have done the job. SteveKris, Richard55...Richard55 was working on a HOW-TO, but got sidetracked when an inner tie rod fell off...
Old December 3rd, 2010, 14:26   #15
oilhammer
oilhammer's Avatar
Yeah, some folks have had good luck fixing them. I have never been brave enough to try that myself.
oilhammer
Page generated in 0.15215 seconds with 10 queries
[Output: 121.88 Kb. compressed to 100.43 Kb. by saving 21.45 Kb. (17.60%)]
