Old April 14th, 2010, 10:39   #1
STRANGETDI
Default Emergency Brake - Rear Left Wheel issue?
Hi all,
I noticed this morning as I was parking into my space at work, that my E-brake had about 1 1/2" of free pull (basically the first click) before I feel any tension. This is very odd to me, as I always had tension. Does anyone know how this happens?
Is something stuck at the brake at the left rear wheel?
I also noticed that at the left rear wheel, my fender gap is about 3/4" higher than my right rear. It wasn't like this before. Is this linked to the e-brake? Currently I am parked on level ground with the car in gear. Not going to use the E-brake until we figure this out.
Can some of you chime in with your thoughts about this?
Thanks guys (and Gals),
Chris
1999.5 Golf TDI ALH
Chris
CURRENT: 2013 Audi A3 2.0T (Gas) Premium Plus Quattro
Gone: (Buyback 4/18/18) 2012 GOLF TDI w/ TECH, 4DR, 6SP MANUAL, 121K miles
OLD: 1999.5 Golf GL TDI,Up'd,.216s,17 OZ Rims,Eibach Pro-Kit&Dampers,TT SS 2.5" Exst. 222,000 - Sold to Rossman83
STRANGETDI is offline   Reply With Quote
Old April 14th, 2010, 13:49   #2
Powder Hound
Powder Hound's Avatar
E-brake cables like to corrode and stick. The best way to check is to examine the outside of the cable for any swelled spots. If there are any, buy a new brake cable. If nothing visual is obvious, you will need to release the cable ends from the calipers and verify that the cable slides easily. You will also want to know that the parking brake mechanism in the brake caliper operates correctly (no binding). But usually this problem is corroded cables that will not move and cause one caliper to hang onto the rotor or refuse to allow the e-brake to work on that caliper.
HTH
Old April 15th, 2010, 10:38   #3
STRANGETDI
Thanks Powder. Took a look at the Bentley Manual last night. Looks pretty straight forword.
Still can't figure out or understand the fender gap issue.
Chris
Old April 15th, 2010, 11:07   #4
Herm TDI
Herm TDI's Avatar
Default broken coil spring
Originally Posted by STRANGETDI
....Still can't figure out or understand the fender gap issue.
Check for a broken coil spring. Check the bottom ends (of the spring) and see if it looks jagged.
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Page generated in 0.11776 seconds with 10 queries
[Output: 60.77 Kb. compressed to 54.01 Kb. by saving 6.76 Kb. (11.13%)]
