Old December 2nd, 2007, 19:35   #1
Beezman7
Default Looking for some advice???00 beetle
I need some help ive taken the role of caring for my girl friends 2000 beetle TDI .....woooo
So i signed up for this site first...and yes this is my first post ...wooo #2
Im no stranger to VW's just TDIs' Im a long time member on VWvortex.com
Ok to my questions first ....I want to upgrade Exhaust , I know TTuning makes one for the Bug are there any others out there???
2nd question ecu module whats the best route for plug and play ?????
Thanks for any advice ............
00 TDI Beetle
04 IS300
Support the Troops ---OIF Vet
Beezman7 is offline   Reply With Quote
Old December 2nd, 2007, 20:05   #2
crazyrunner33
crazyrunner33's Avatar
Welcome to the club!
1) The exhaust upgrade won't do too much w/a stock vehicle. A lot of people on here will just make a straight pipe instead, it'll lower the EGTs a little bit and it'll make the turbo whistle louder.
2) For the best plug and play tuning I would have to say it would be the Qloader. You can get it from KermaTDI. Basically they email you a custom tune, you load it on to the Qloader which plugs into the OBD2 port and it'll upload the tune to the ecu.
Another way would be to get it chipped by Rocketchip. Or you can get a tuning box from JSPerformance.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
Old December 2nd, 2007, 21:04   #3
Beezman7
You dont would think just like on non TDI vws that a free'r flowing exhaust with better muffler and better flowing pipes would do min. increase in performance?? I would think it would be better for the turbo just like my VrT....
00 TDI Beetle
04 IS300
Old December 2nd, 2007, 22:52   #4
droppedjet
Fuel Economy: 45/50
Its A bettle dont do anything to it...lol im just playin but yeah I would do a downpipe and and the q-loader chip and drop it thats it
//M3 FTW!!!!!!!!
droppedjet is offline   Reply With Quote
Old December 3rd, 2007, 01:19   #5
Ed's TDI
Ed's TDI's Avatar
Fuel Economy: 5.7 / 5.1 / 4.5 L/100km
Something you need to realize about diesels is that it's not the increase in air that increases the power, it's the increase in fuel. The extra air/boost just cleans up the smoke and keeps temps down. Your girlfriend's TDI will benefit from some simple fueling mods (bigger injector nozzles are a cheap one, a tuning box is another option, and a chip is also a good option).
If you decide to mod her TDI, I'd suggest you take a bit of time and make sure the car's in top running condition first. Usual stuff like timing belt, intake cleaning, general maintenance, etc. Then take a minute to decide with your girlfriend what she wants to do as far as power goes, then make a plan and buy the parts you need (do some reading on here to figure out what parts you have to chose from). By the way, make sure that you budget for a new, upgraded clutch if you plan on any more than 2 power mods.
Good luck and welcome to TDI Club!
First documented MK4 VNT20 Installation in North America!!
Done by JS Performance in Abbotsford, BC, Canada
Ed's TDI is offline   Reply With Quote
Old December 3rd, 2007, 03:24   #6
Richard55
Richard55's Avatar
TDI(s): 2000 NB
Fuel Economy: 52 MPG
what the h+ll you taking about, "Its a beetle don't do anything to it" I also run a 2000 NB, have installed several mods and would stack it up to any tdi on the interstate for power and punch. It is only Audi TT platform with a different shell on top. A good mod NB will outperform any tdi on the road, (that should raise some response). Rocketchip is the way to go, harder to get but well worth the wait.
"Speed cost money, how fast do you want to go."
RC6, 11 mm IP, 17/22, egr delete, 3 inch exhaust, 2.5" custom lower IC pipe, lift pump, "LurkerMike" custom DP, PP764, MAF deleted, 3 bar MAP, stage 2-14 lbs flywheel and clutch assy. Autometer Colbalt 2 Oil Pressure, Boost and EGT guages. K&N air filter. 18" Motegi wheels. vent and snowectomies. 55 watt HIDs
Richard55 is offline   Reply With Quote
Old December 3rd, 2007, 12:39   #7
Beezman7
Well i figured to get a little better exhaust on there cause its going to need a new one....dont have to worry about clutch its an Auto...Reason for some mods is its dawg slow so i want to put a little more pep in it for when i drive it lol . Any one in here running a TTuning exhaust?? what size is the stock exhaust? What are the best simple plug and play adds. nozzles install very hard on those?
00 TDI Beetle
04 IS300
Old December 3rd, 2007, 12:41   #8
Beezman7
Also car is up to date with all maint. goes to VW when ever something is do...
00 TDI Beetle
04 IS300
Old December 3rd, 2007, 12:44   #9
Antsrcool
Antsrcool's Avatar
If its an auto then expect to put a new trans in once it is modded the trans have a BAD rep
Antsrcool is offline   Reply With Quote
Old December 3rd, 2007, 12:44   #10
Antsrcool
Antsrcool's Avatar
search O1M trans
Old December 3rd, 2007, 15:04   #11
crazyrunner33
Originally Posted by Beezman7
..... nozzles install very hard on those?
They aren't too hard to install. There's a pdf file around here on how to do it. It only took me about an hour to install mine.
Old December 3rd, 2007, 15:47   #12
Richard55
Richard55's Avatar
TDI(s): 2000 NB
I tool my NB to the local muffler shop and the 3" system, from before the cat to the rear was only $125.00. It will last as long as I have this car.
Old December 5th, 2007, 03:57   #13
Beezman7
How loud is it compared to the stock exhaust , what muffler did you go with if any?
00 TDI Beetle
04 IS300
Old December 5th, 2007, 03:59   #14
Beezman7
I dont want to go to crazy just a little more pep ....
00 TDI Beetle
04 IS300
Old December 5th, 2007, 03:59   #15
Antsrcool
Antsrcool's Avatar
Dont use a muffler and its not much louder your turbo will whistle a bit louder thats about it really as mentioned read up on that trans b4 you mod this car
Page generated in 0.15531 seconds with 10 queries
[Output: 122.17 Kb. compressed to 100.67 Kb. by saving 21.50 Kb. (17.60%)]
