busa_chris
A little background... Drove the car for the past couple of months with no issues (finally right?). Parked it this past Friday night in my driveway (where I always do). Come out early Saturday morning and it wont start. Turns over but wont fire up. I don't have VCDS but I do have a generic scan software and dongle. Pulled the codes and I had a crank sensor code. Went and picked up a new one first thing this morning from AARodriguez since he's local. 10 minutes to swap it out... still wont start.
Tach is moving now, showing that the crank sensor is working. The cam sensor was replaced today to (its been bad since I got the car). Fuel tee on the filter was also replaced because the date stamped on it was '03 and its probably time to change it just because. The lift pump was just replaced a month ago. I am getting fuel on the return line. I am getting fuel in the cylinders because I can smell it when cranking. I've checked the 109 relay and its good.
Im lost here. Im getting fuel, tach is moving, ASV is open... what else could there be? Turbo vanes are not stuck. EGR doesn't matter (deleted). I checked the connection on the side of the head for the injector harness. The pins all look nice and shiny. No condensation or anything suspicious. I really need the car for work tomorrow, so any help is greatly appreciated!!
