EvilLawnGnome
So I'm fighting a low-boost on my 2005 Jetta Wagon (BEW) with ~225kmi on the clock. I threw a vag-com on it and the requested boost looks normal, but the actual boost lags wayyyy behind. It eventually throws an underboost code and goes into limp. I've tried throwing an n75 from an ALH onto it, but that didn't seem to resolve the issue. I've was also able to get to the actuator and move it by hand, and it moves smoothly and freely. This all happened shortly after the short rubber hose between the fuel pump and the fuel rail sprung a huge leak into the driver's side of the engine bay. I haven't been receiving any MAF or MAP codes aside from the low-boost. I was thinking toasted turbo, but I am not seeing any excessive oil or smoke.
Any thoughts?
Any thoughts?
