The crank pulley has not been removed, I just used it for the crank timing adapter and when the flywheel timing mark was at tdc and cam lock in place the crank lock fit right in as did the ip locking pin.
(some deleted)
IF the pulley has moved I realize the piston would not be where it should, so can the pulley be off and the crank lock fit right in along with all the other pins and locks and give you a false piston position?????
I don't know what the 'crank lock' is unless it goes on the crank gear to lock it.
I thought were for BEW engines, I never used one.
For the pulley to move the keyway would have to shear, partially if not fully.
I don't think you want to remove it and go through the tightening process which is not easy from what I hear.
I don't think it's necessary.
If the TDC mark on the flywheel is at TDC and the cam lock slips right in you should have those two correct.
I had the pump timing off once (2nd belt) and it wouldn't start. Other tech told me he saw some white smoke out the tale pipe.
I put the cam lock in again, with the flywheel at TDC.
I loosened the 3 bolts on the pump gear.
Took the belt off, turned the pump until the lock pin went right all the way (there is a dummy hole that I hit on the 3rd belt) set the 3 pump bolts to be about in the center of travel and tightened them.
Car started right up.
If this isn't working I would start thinking about water or such in the tank or such. If that wasn't asked already.
Maybe drain the filter into a jar, see what comes out?
