WildChild80
- Joined
- May 30, 2016
- Location
- Nashville, AR
- TDI
- 2001 Jetta TDI 2000 Jetta TDI 2000 New Beetle TDI ALL 5 speeds
Would cam to crank timing not cause low compression? You said that your cam lock didn't drop in what the crank was at top dead center, did you correct the cam to crank timing prior to the compression test?
Sent from my Pixel XL using Tapatalk
