Have a 2002 alh jetta manual.
The problem I’m having is that I started the car to let if warm up for a few minutes went inside my house and when I came back out the car wasn’t running anymore.
So I was think this it possibly ran out of fuel sense I’ve been have a issue lately with the cluster not fully working.
I went ahead and put two gallons of diesel in it and put some fuel fuel filter from the t-fitting
Then I cracked the nuts on the top of one of the injectors and saw a few bubbles and little bit of fuel come while cranking tightened up the buy and tried to start it and still nothing. Even did that same process for all for injectors and still just cranks but not start
Also check the ohm reading on the fuel sender under the back seat and getting about 150 ohms I don’t know that related to my problem or not but checked it anyways.
Any time to help of direction towards getting this thing started would be greatly appreciated.
Thank you
Thank you
