Drewmeister
Today was pretty hot and it seemed to take a little while for the A/C to get cold, so I decided to check the radiator fans when I got home. Good thing I did, since I found this:
So apparently that's fuse S177, 150A on the wire to the alternator. I guess this could happen just due to corrosion or a poor connection, but could it be indicative of an alternator problem? The black wire was hot even several inches away from the connector (which was off course too hot to touch), and the red wire next to it was pretty warm also but not as bad.
Battery voltage seems normal, maybe slightly low. 12.40V key off; 12.21 key on, running VCDS scan (no codes). Hooked up a battery charger which showed it at 75% charge and fully charged it in about 10 minutes (10A charge rate). 12.56V after letting it sit 15 minutes (disconnected from charger, still connected to car).
Started engine, voltage at battery posts was 13.31V. Definitely low, but maybe caused by the high-resistance connection; unfortunately I forgot to check voltage at the alternator itself. After running just 90 seconds, the connection at the fuse block was very hot and I smelled melting plastic, so it's not drivable like this.
Obviously I need to replace the fuse block, and probably the cable too, since even if I shine up the connector, the crimp doesn't look so good any more. I took out the alternator and am going to have it bench-tested. I hope the alternator is good, but on the other hand, having this happen with a "good" alternator isn't so great either.
(Oh, and the radiator fans are working properly.)
