pianodirt
2000 Jetta tdi
I have a flashing red thermo dash light and a solid brake sensor light. About a week ago I checked for fault codes and found several. The thermo ones I think were some sort of intermittent issue and the brake one had to do with intermittment ABS connection. I did not clear the codes and unfortunately was in a rush and didn't save them. Today I have scanned all controllers and cannot find these fault codes any more. I did not clear them before. Visually, all four brakes look good and the Master Cylinder is full up. I think I do have a leak in my cooling system, but the code(s) should still be there, right?
I've tried this on VCDS 16.8.0 and 16.8.1, same results. What could I be missing here? How can fault codes "disappear" but still showing dash indicator lights?
Thanks for any insight you can offer.
